Driver side door open/close sensor failing.
Old Jan 28, 2011 | 04:59 PM
chasekanter's Avatar
Default Driver side door open/close sensor failing.
Hello everyone,
I ran my H3 through the power wash today and now it thinks my driver side door is open when it isnt. I narrowed it down to the driver side door because when i lock the doors only the driver side instantly unlocks. If i push the sensor in with my finger it still thinks the door is open. Has anyone else had any issues with the door sensors failing? I tried disconnecting the battery for 5 min and reconnecting. Didnt fix it. I really doubt the power wash got it wet but i could be wrong. Any suggestions would be greatly appreciated.
Old Jan 28, 2011 | 06:32 PM
Widespread Hummer's Avatar
You can unscrew the switch from the body with a torx head screwdriver. Pull the rubber boot out of the body and there is a simple plug on the back that you can check for moisture or corrosion. I had the same problem whenever the vehicle got wet. I cleaned my switch but the problem returned a few days later. I don't remember why I did it but I ended up swapping the drivers door switch and tailgate switch which solved the problem.
Old Jan 28, 2011 | 10:15 PM
RKSmith163's Avatar
gmpartshouseusa.com It is called a jamb switch and it will cost you $6.07. It is easily removed by taking out 1 torx head screw. I replaced the one on my rear door last night. It seems to get wet and fail. This time I put NO-OX on the connector side and put silicon over the 4 small slits on the switch side. The same switch fits all 5 doors.
Old Jan 29, 2011 | 12:28 AM
Welcome to the club. I have had 3 differnet jamb switchs replaced at the dealer under warranty. The head HUMMER tech (when it was a HUMMER dealer) use to keep 5 or 6 of them in his tool box beacuse he got sick of walking to the parts counter so often.
Old Jan 29, 2011 | 07:16 AM
Sounds like an easy fix. Thanks for the help everyone!
Old Jan 29, 2011 | 11:15 AM
ElliotF's Avatar
Smile
I had the same problem with my rear door light switch. I unplugged it, cleaned the connector contacts with contact cleaner and then filled the connector with Dielectric Grease. Dielectric grease keeps water out (prevents corrosion) and the contacts will still connect. It worked so well I did the same to the other 4 door switches just in case.
pauly1052
Jun 27, 2015 04:51 PM
mcioci
Nov 2, 2013 08:53 AM
FurbiesAndBeans
Jun 9, 2010 10:58 AM
davetrader
May 22, 2007 07:30 PM
khelms_98
Dec 25, 2006 04:38 PM
