Drilled Slotted Rotors
Old Aug 31, 2007 | 09:44 PM
JeepeaterH3's Avatar
Default Drilled Slotted Rotors
anyone upgrade rotors? is it something you suggest?
Old Aug 31, 2007 | 09:46 PM
Heysdad's Avatar
Default RE: Drilled Slotted Rotors
Do you know of someone that sells drilled rotors for H3's?
Old Aug 31, 2007 | 10:02 PM
search ebay. hummer h3
i sorted from expensive to cheap. 279$ free shipping!
Old Aug 31, 2007 | 10:19 PM
saywhat's Avatar
If It was a Sports car or a SRT8 Jeep I would say go for it, Not on a Hummer!
Old Aug 31, 2007 | 11:19 PM
GarrettMoore's Avatar
I've seen a guy on ebay selling pads, and drilled/slotted rotors for the H3, with incredible feedback, and people noting they were repeat customers.
If it wasn't for that, I would say stay away from anything drilled. For the most part, companies make standard width rotors, then drill them, which causes them to be very weak, and crack.
You may say that you have seen drilled rotors come stock on certain cars, exotics mainly, but this is becaue they increase the width of the rotor, adding the neccessary strength for drilling.
Old Sep 1, 2007 | 10:19 AM
so bottom line.. dont do it? i offroad alot, i dont need cracked rotors. lol
so bad idea huh?
Old Sep 1, 2007 | 11:05 AM
671H3's Avatar
I say don't get it. It only looks good IMO.
Old Sep 1, 2007 | 11:26 AM
D VADER's Avatar
Pads and rotors have come a long way. Drilled/slotter rotors are for looks only unless you increase the size of the rotor.
Old Sep 1, 2007 | 01:23 PM
CCMDoc's Avatar
DVader is 100% correct - drilled rotors are for looks only - loss of metal = loss of surface area and decreased heat transfer = loss of stopping power.
Slotted rotors - depends upon the location, number and direction of slots. For frequent stops from high speed (180mph- - >40mph) where gassing might cause pad float, properly slotted rotors allow gas to escape and more immediate friction to be applied. In any other situation, slots =less surface area=less stopping power. Unless with the change in rotors comes increased diameter and that increase equals or exceeds the loss of surface area from the slots or holes compared to stock, it is always a losing proposition.
Old Sep 1, 2007 | 11:54 PM
Hawaiian Hummah's Avatar
not to mention that it will eat your pads two or three times faster
