Door Panel Removal
Old Oct 10, 2009 | 09:47 AM
wfturner's Avatar
Default Door Panel Removal
I have a 07 H3 and I want to remove the driver side door panel.
If any one knows a procedure for this please let me know
I did a search, but came up blank
Thanks in advance
Old Oct 10, 2009 | 08:12 PM
BrickWurX Mfg.'s Avatar
You should have one Torx bit screw behind the door latch, and two on the door pull iteslf, behind a removable face panel. Start at the base and pulled the "pop" catches free, working your way up until the door panel can lift out of the window track. It is best to do this with the window down as to not scratch anything accidentally. The door latch and lock cables can be disconected via rotating them for removal. No tool needed here.
Old Oct 11, 2009 | 08:07 AM
wfturner's Avatar
Thanks for the info
That seems pretty straight forward
Old Oct 18, 2009 | 09:20 AM
r_wichman's Avatar
I just replaced my wife's mirror on her passenger side, it was pretty easy. pannel comes off and on with out much of a hich. Also, the dust seal uses an adhesivie that is reuseable. Not alot of work for the money saved.
aaronballard0033
Jul 15, 2012 10:51 AM
blackterror
Jun 21, 2009 09:03 PM
Ray
Mar 15, 2009 03:32 PM
hman969
May 12, 2008 02:13 AM
bmbenear
Aug 23, 2007 03:18 PM
