Door Moulding/Trim & Part ID Question
Old Apr 30, 2012 | 03:12 PM
diack's Avatar
Default Door Moulding/Trim & Part ID Question
Hey All, got 2 questions.
The first, how do you go about identifying OEM parts, is there a web catalog or source i can access without dropping $200 for a GM Service Manual. I may do an odd repair here or there, but that cost is lost on me as i would never get under the hood or chassis.
The second, can you help me identify the part in the following image. It's the rubber trim that goes over both doors. As you can see on the photo, where it does the corner, its banged up pretty well. I intend to replace this along with some other things to see if i can fix my leak issues. Both the driver and passenger side moulding is in the same shape.
Thanks, diack
Old Apr 30, 2012 | 04:19 PM
diack's Avatar
Sorry left out. this for an H2 2003
Old May 1, 2012 | 09:07 AM
fyr145's Avatar
Thats the weatherstrip on the body above the door on the left side; part # 25868657. You dont need to spend big bucks on a service manual, just click over to Hummer Parts
and do your own searching for parts. Now, pricing can vary between sites. I like buying my OEM parts from gmpartsdirect.com. Their prices are usually lower than most others.
Hope this helps.
Old May 1, 2012 | 10:41 AM
diack's Avatar
thanks man i appreciate the help.
Old May 11, 2012 | 09:16 AM
hobcog2000's Avatar
Default thought you'd like to know
Hope this helps.
I like gmpartsdirect.com bought a air level sensor for 50 bucks cheaper than the dealer a couple weeks back
Old May 11, 2012 | 10:09 AM
bflorin's Avatar
when that origional seal shrinks, those top corners are where it pulls away from. You can get buy pulling it off from the bottom up and glueing it back from the top down. You will have a bigger gap at the bottom...but it wont cost you anything but the trim sealant.
mrigor
Sep 4, 2012 10:26 PM
06redhummer
23
Jul 17, 2012 10:32 PM
GET OUT D WAY
Jun 22, 2012 07:16 PM
FBINA234
Jun 3, 2012 11:06 AM
rwdr
Feb 16, 2011 09:29 AM
