door lock
Old Feb 12, 2008 | 07:30 PM
inopunkbeach's Avatar
Default door lock
on the cluster the doors is liteing up mean there is a door unlock but there isn't and the doam light is on and won't turn off also the drive side door won't lock anyone no what it could be help!
Old Feb 12, 2008 | 07:36 PM
Hawaiian Hummah's Avatar
Default RE: door lock
back door (with the spare on it) must be open, or one of the doors
Old Feb 12, 2008 | 07:38 PM
i tryed all doors and they where all closed i had to disconnect the battery so the battery won't die
Old Feb 12, 2008 | 07:53 PM
rhill20's Avatar
Unless one of your doors has been bent out of shape, you have something in the door jam preventing it from closing all the way, or the back door isn't shut completely you might have a short. Your electrical SHOULD shut down after 20 min to prevent the battery discharge, so you shouldn't have to disconnect the battery everytime. Check it first though to make sure it is working.
I would get with the dealership and have them look at it.
Old Feb 12, 2008 | 08:00 PM
yeah i was trying to check but it is raining really bad but i wasn't sure if the light would turn off so i disconnected the battery and by the way your hummer all black out is that **** i am doing the same to mine i almost have it done
Old Feb 12, 2008 | 08:08 PM
rhill20's Avatar
Old Feb 13, 2008 | 08:26 AM
BMJM100's Avatar
Mine did the same thing last week. It was icey outside and one of the door switches must have got frozen, it went away after an hour.
Old Feb 13, 2008 | 08:41 AM
importkiller's Avatar
definately a door switch problem....open all doors and work the door switches real good...make sure theay are not sticking. I would tape down all 4 door switches and see if the DIC message and dome light go away...if yes then you have a door not making contact (unlikely) or a bad door switch (unfortunetly kinda common on gm's). Remember...DO NOT just cut the wires off a door switch and splice them together to bypass the bad switch (like we used to do) the system on the H3 is controlled by the BCM and cutting out a switch isn't a good idea.
Old Feb 13, 2008 | 09:34 AM
macahill's Avatar
I had this happen to me last summer, no Ice, no rain. I jiggled all the door switches thinking one was stuck to no avail. So,I had On Star run a diag, which did nothing, everything checked out "OK". I had an appointment with the dealership to check it out, but I fixed it before having to take it in. Here's what I did:
Sit in the H3 and arm your alarm(press the lock button on the remote/engine off). Open the door and this will set off the alarm. Press your remote to shut off the alarm. The Door open indicator, and dome lite now work as they should - for me at least.
Must have been some kind of problem with the alarm mechinism/door sensors, and this reset it. I suppose just hitting the panic button on the remote may work as well, but it has never happened again so can't say it would work or not.
hope it works for you -
Old Feb 13, 2008 | 10:21 AM
blackbear's Avatar
I think that it's a BCM glitch, this happed to me twice, I disconnected the battery both times over night and it was all good the next day.
