door handle problems
Old Oct 26, 2014 | 12:02 PM
stevenmurph7's Avatar
Default door handle problems
Hey guys I'm new to the forums so thank you for any help. My rear drivers side power window motor went out so I was able to take the panel off replace the motor etc. But when I went to put the door handle back together it just won't work. It is limp and doesn't seem to be pulling when I try to use it. I connected the cables to the door handle correctly so Im nor sure why it's not working.
Old Oct 26, 2014 | 06:13 PM
Did the door handle operate properly before you replaced the window motor?
Old Oct 26, 2014 | 10:59 PM
jerms212's Avatar
Did you pull the cover back off the make sure the cable didn't slip off the clip when you were reinstalling it? If you did that, trace the cable to where it meets the latch and make sure you didn't knock it loose installing the new motor.
APSIS USA
Jul 11, 2008 03:50 AM
Crushem
Apr 8, 2008 08:16 AM
hummana
Dec 20, 2007 04:25 PM
danaw
Apr 23, 2007 05:30 AM
danist
Dec 5, 2005 03:37 AM
