Dead battery/key locked in ignition
Old Dec 17, 2007 | 02:53 AM
Steve #1's Avatar
Default RE: Dead battery/key locked in ignition
ORIGINAL: HERHMR
1) Is this some type of security perk the H3's have with the key locking itself in the ignition when the battery is stolen or something?
2) What's the procedure for me to designate the cig outlets to default off when the key is turned off?
1) The H3 uses an electronic ignition lock that disengages when the vehicle is in park. By default it is engaged so if there is no power it stays locked and holds on to your key.
2) The easiest thing to do with your radar detector is to remove the power point plug and hard wire the detector in to a switched power supply (radio circuit etc.). Not only will this shut off the detector with the ignition switch, it also eliminates having a cord connected to the dash.
Old Dec 19, 2007 | 12:27 AM
skeeet's Avatar
Just never have you batt. go dead when the front is up against the wall and you can not open the hood or get it into neutral so you can roll it away from the wall. That is a pain.
Old Dec 19, 2007 | 09:26 AM
HERHMR's Avatar
ORIGINAL: Steve #1
ORIGINAL: HERHMR
Steve#1, re:#2 above, thank you so much, I will try this !!
I also thank you all for your comments and suggestions!
My New Years resolution is to make the time to be a Contributor to this forum. I am so very thankful for all the help and fun this forum has given me all year long. Oh and of course, I want to add a little bling in my avitar with that little yellow CONTRIBUTOR logo.......! ha. Oh, I mean rough and tough CONTRIBUTOR logo (for those of you who shreek at the word bling).
I will go to: HummerForums.com Contributors
Old Dec 26, 2012 | 09:07 AM
paula b stubblefield's Avatar
Default key locked
the battery is dead on the H3 and the key is locked in the ignition..but so is the hood locked so i can not get it to release when i pull the handle inside. How do i get it to release that so i can get under and charge the battery?
Also is it normal when he battery is dead and the key is locked like it is that the steering wheel is not locked?
Old Dec 26, 2012 | 10:25 AM
happythree's Avatar
The hood release is a cable,it should open IF you pull the hood release.
If not ,send me an email.
Old Dec 26, 2012 | 10:51 AM
It helps if i was not a newby at this and would look at what i was pulling so hard on. we have his and hers H3s and husband usually takes care of things but it is his that is/was acting up and he is working 12 hrs today.
If i pull on the hood handle in place of the parking brake release it works...
got the key out and it is on the charger.
Thanks and will be lurking here lots to learn more about my early Christmas present
Old Dec 26, 2012 | 11:11 AM
It would be best if you did NOT dig up FIVE year old threads!
hmer
Mar 15, 2014 12:55 AM
Nate2106
Feb 8, 2014 06:31 PM
navipb
Jan 9, 2013 02:23 PM
doyleh3
Apr 2, 2008 10:01 PM
H3 Xman
Dec 18, 2007 09:34 PM
