CTIS and aftermarket rims
Old Jun 24, 2013 | 11:58 AM
Godwinrb's Avatar
Default CTIS and aftermarket rims
Thinking of replacing my rims for after market rims. My H2 has the system that you can deflate the tires by the push of a button for more traction if off-roading. I read up on the CTIS but I'm not seeing anything about a monitoring system but I assume there's something there for this to be able to work.
So, I know the system won't work if I replace the rims and I'm fine with that, but with it throw an error code?
Old Jun 25, 2013 | 05:07 AM
Godwinrb's Avatar
Anyone?
Old Jun 25, 2013 | 06:25 AM
The H2 does not have CTIS. It hasa ride evening system that raises and lowers the rear end up to 2" inches. Changing rims will not impact the system and will not throw any codes.
Old Jun 25, 2013 | 09:00 AM
Godwinrb's Avatar
That's great, but now I have another question. I have a button in the same are as the raise and lower rear the rear. It has the #2 with a TPMS symbol. I thought I read in the manual that this button would deflate the tires for more traction? Is this not the case?
Old Jun 25, 2013 | 11:13 AM
H2CANEPADESIGN's Avatar
Like 3hummers stated, the H2 did NOT come with a ctis system, nor was it an option. the ctis system inflates and deflates your tires from a compresser that connects via airline directly to your wheels. you would be able to see it if you had one. the button that your referring to just raises the rear end a few inches when off roading. it controls your air springs if you still have them installed.
the other button that your referring to is the traction control. the #2 means its only on the other two tires, I forget which axle front or rear but you can activate it in 4 high locked.
Old Jun 25, 2013 | 12:07 PM
atvspeed4's Avatar
The "other button" allows higher wheel speed spin in situations such as sand and mud.
Old Jun 25, 2013 | 12:27 PM
Godwinrb's Avatar
Great, thanks.
Old Jun 25, 2013 | 12:49 PM
That's why I love this forum. Just when you think you have your car figured out you learn something new.
saumo
Feb 13, 2013 09:33 AM
r390radio
Jul 21, 2010 09:40 PM
silvercrw
Jul 21, 2009 05:08 PM
Outlaw6Guy
Jan 14, 2008 10:38 AM
importkiller
Jul 12, 2006 01:43 PM
