Cold air intake?
Old Jun 29, 2006 | 10:05 PM
Raffi76's Avatar
Default RE: Cold air intake?
Thanks ! I change oil every 3000 miles...... I dont drive up and down constantly, I usually only get to work and then when I go home I leave, lunch rarely. now you are saying the sand will clear the air better? but wouldnt the sand get inside the compartment to whichever the air is going to ? I would think that would be a bad thing.....
Old Jun 29, 2006 | 10:31 PM
dilo2001gt's Avatar
Raffi you can always add this
Description:
K&N Filter Wraps work to prolong the life of your K&N FilterCharger when used in extremely dusty conditions, while also giving your engine that extra bit of style. Durable, double stitched polyester material traps dirt particles as small as .005" in diameter, yet still allows for a 90% airflow rate. Custom made for each application to ensure a perfect fit onto your filter.
[IMG]local://upfiles/111/D58990F7C774497985690786127F90A7.jpg[/IMG]
Old Jun 30, 2006 | 07:01 AM
illusn's Avatar
There are a couple of things missing:
The kit for the 2006 H3 comes with a bracket that bolts to the bottom of the tube and to the side of the head for added support. It also has a area on top for the sensor to be bolted too.
Heres my two cents, save your money and just install the air filter instead of the whole kit. I had the kit for about a week and took it off to much "air swooshing" noise for me. I then installed just the air filter, truck felt the same. One of the best aftermarket parts I installed was the Air Raid Throttle Spacer.
Old Jun 30, 2006 | 12:16 PM
Raffi76's Avatar
thanks dilo ! if I decide not to use that , you suppose I could damage the engine ? I suppose there is dust everywhere, and people who go offroading use these as well...... if so what kind of damage are we talking about?
Old Jun 30, 2006 | 12:51 PM
Dennis's Avatar
Raffi..I know the questions was for Mark...But I'll jump up if it's alright..
There has been some bad rap about K&N and simular types filters, that will allow some fine dust to enter the engine...But After close analysis, I find the results are skewed to defame K&N...I mean, wouldn't you try to against a competitor?...K&N have been around doing this filter thing for many, many years, and if they are not doing a good job of filtering, then they would not still be in business..think about it.
Anyways, as I said any dust that might get by will end up in your crank oil (I hate that when that happens)...So regular oil changes with a new oil filter and at or less than 5000 mile intervals will be your safest insurance to protect from this contamination, should any actually get in...But under certain Sahara type dusty conditions on a day to day basis, I would also use the filter bag that Mark showed us above.
Old Jun 30, 2006 | 01:01 PM
Dennis's Avatar
ORIGINAL: illusn
You are the first person that didn't get all the parts with their K&N kit I've heard of...Also true enough, the sound is louder than the air box filter too, that takes some getting use to if you're not expecting it..But it's only howls a little with heavy acceleration.
And last; If you feel or notice a benifit with the AIRaid throttle body spacer, then more power to you..Again, this thing is a worthless gimick in my opinion and it actually adds a bit of intake restriction. It is supose to swirl the air as it pass through the thing...But once the air is in the intake manifold chambers, it is also swirled for the same reason the Spacer claims it does..So in effect the process of swirling the air is double done needlessly, but I'm not trying to shoot you down if you feel it is worthy.
Old Jun 30, 2006 | 04:04 PM
Raffi76's Avatar
Thanks again and sure you can jump in I mean I am in no sahara coditions.... I work in a Beverage Plant..... many trucks pickup and deliver every day, ofcourse there is regular pavement but most of their parking area is gravel and dirt, so cars usually get dirty parking in the area...... I really only drive here for a minute or so when I come in and then leave work.....
Old Jun 30, 2006 | 04:09 PM
dilo2001gt's Avatar
that explains everything
Beverage Plant.....
Old Jun 30, 2006 | 04:51 PM
Raffi76's Avatar
HyHy I wish it was that kind..... we make Fuze, Glaceau Vitamin Water, Snapple, Sbarro and just starting the Coca Cola Iced Teas
Old Jul 1, 2006 | 05:39 AM
illusn's Avatar
ORIGINAL: Dennis
ORIGINAL: illusn
I understand you comments and don't feel you are trying to shoot me down. I was just giving my two cents and trying to save him some money.
What I mean by parts missing (my kit had everything). I was referring to your photo, I didn't see the bracket that mounts to the bottom of the tube and to side of the head, and the sensor that needs to be mounted on the top of the tube.
AirRaid, all these years I was also hesitant about installing this item. But after hearing numerous stories from friends who have installed this on numerous vehicles and their claims. I decided to try it since the H3 needed all the help it could get. Since this is such a easy install, I have removed it tested the vehicle, replaced it and tested the vehicle and there is a difference. For $100 investment a noticeable difference could be felt versus a $250+ investment for a airfilter system. But still its only a 5 cyl.
07 Cadillac Escalade
06 H3
05 BMW 545i
04 H2
03 MB E320
02 Harley Davidson Truck
00 Lincoln Navigator
and the list goes on...
