Climate Control back lighting
Old Apr 11, 2011 | 09:14 PM
Ken06H3's Avatar
Default Climate Control back lighting
My climate control temperature control backlight seems to be out. I can press it for AC and the yellow indicator lights up. It performs the indicated function - hot or cold temperatures.
Is there a replacement bulb/led or does require dealership repair? Or has it never illuminated?
Old Apr 11, 2011 | 09:27 PM
airborne227's Avatar
The whole thing (all three controls/***** are one unit) needs replaced, unless you know how to solder. You might be able to find one on Ebay cheaper than the $200+ the dealership will charge. Luckily I had mine replaced just before I passed 50,000.
Old Apr 11, 2011 | 10:37 PM
Draketh's Avatar
I just had mine replaced too! I'm milking my warranty for everything I can get before it runs out.
If you're good enough with an iron to solder micro LED's you can pull it off, but I just said screw it and let the dealer handle it.
Old Apr 11, 2011 | 10:51 PM
drtom's Avatar
Banned
seems to me this has been covered a few times,in detail,,a cheap fix.
maybe a search will help
Old Apr 12, 2011 | 12:39 PM
Draketh's Avatar
I know there are pictures somewhere, but I don't think its on these forums, I remember seeing it on one of the other hummer forums.....
Old Apr 12, 2011 | 01:02 PM
Broken Halo's Avatar
I had it bookmarked.....it was worth saving!
https://www.hummerforums.com/forum/h...removal-16478/
Old Apr 13, 2011 | 10:20 AM
branstone's Avatar
i am confused though, you say when you push it it lights up, what else is it supposed to do? it is off then you push it and it comes on.....
Old Apr 18, 2011 | 09:17 PM
Ken06H3's Avatar
The purpose of my post was about the backlight showing the cold/hot (blue/red) indication. The amber light will come with or without the light system on. The replacement seems to be in $400+ range, so this may remain this way for awhile.
Thanks for all the feedback.
Old Apr 1, 2013 | 07:03 AM
greenhummer's Avatar
I have the same problem but now another problem came on the stability system light came on and i looked at the leds above the climate control dash,
it was off, same as the climate contol.
Today my 4x4 up lock its out im guessing it will keep buning out until i replace the thing?
Does the dealer when yall say replace the whole control assebly doesbit include the upper control aswellvor wouldbi have to pay extra for those?
Old Apr 1, 2013 | 12:24 PM
telemike's Avatar
I bought a set of three lightbulbs for $15 off eBay that are direct fit replacments for the heater unit. The PITA is opening up the controls box to change them out.
drgray7
May 19, 2010 10:55 PM
sanders1
Apr 6, 2009 11:59 PM
matelblapav1
Feb 1, 2009 06:37 AM
HammerDown
Aug 30, 2007 04:54 PM
crc2k
Jul 14, 2006 11:54 PM
