Check engine light
Old Jan 29, 2015 | 09:45 PM
09 Black H2's Avatar
Default Check engine light
H2 sat for about a week. Started up battery a little weak. Check Engine light came on. Drove and restarted twice. Returned home charged battery. Engine turns over no start. Disconnect battery cables and slow charge battery all night. Reconnect battery and vehicle started, no check engine light. Replaced battery. All starts fine drove about 30 minutes, park and will not start, turns over and check engine light back on. Wondering if this is pass lock or ignition switch
Old Jan 29, 2015 | 10:23 PM
Signal25's Avatar
Go by Autozone and have them check the codes.
Or get the $10 OBDII BT reader and do it from your smartphone/tablet.
That code would help a lot right now.
Old Jan 29, 2015 | 10:27 PM
Son ran code reader. Fuel pump control module disconnect.
Suggested fix replace data bus cable
Old Jan 30, 2015 | 12:00 AM
Signal25's Avatar
Best I could find. Seems like the connector has problems.
http://engine-codes.com/uploads/gmc/08-07-30-021E.pdf
Old Jan 30, 2015 | 04:36 PM
Made it to dealer today. Started fine after hooking battery up. Engine light came on approx 5 minutes after starting. And at dealer they started it several times. Unknown!
Old Feb 4, 2015 | 08:41 PM
Fuel pump and fuel pump contro module.
Poweraidion
Feb 16, 2014 11:26 AM
joenuzz
Aug 21, 2010 10:24 AM
deejaykaygee1
Jan 20, 2010 04:57 PM
jrippel
Nov 29, 2006 08:36 PM
importkiller
Nov 4, 2006 04:02 PM
