Check Engine code P0033
Old Nov 15, 2009 | 01:08 PM
therobesons's Avatar
Default Check Engine code P0033
I got a scanner at Walmart.
Plugged it in, saw code, then cleared the code.
So I am guessing at what the code was but I think it was P0330.
it said "P0330 Knock Sensor 2 Circuit low voltage (Bank 2)"
Is this something that may cleanup with Injector cleaner run through the fuel system?
Bob
Old Nov 15, 2009 | 06:22 PM
2wheelmonster's Avatar
A knock sensor to my understanding is to monitor the camshaft or the crank as it spins. I'm not a 100% on this, but I do know that injector cleaner will definitely work. It's like an O2 sensor, when it says low voltage it usually means the sensor is bad. I found that going to the autozone website and looking up the parts they also have pictures with it on where it is located on the engine, so that should give you a good idea on what to look for.
Old Nov 17, 2009 | 08:49 PM
Tiny's Avatar
The Knock sensor is under the intake and a pain in the butt to change. Mine was acting up for awhile before I changed it(about 6 mounths). The bad thing is I belive it cased my catilitic converter to go. They go bad from water/mud settting down in the intake valley. It's a bad design from GM on the 6.0 and other engines. Took me about 3 hours.
Raffi76
Nov 18, 2014 12:48 PM
quadblaster240
Mar 29, 2013 02:34 PM
user 956363738
Jan 19, 2012 10:14 AM
h2con
Sep 24, 2011 10:14 PM
06H34ME
Feb 15, 2010 08:57 AM
