In channel Visor problems
Old Jan 26, 2013 | 12:18 PM
ceverts001's Avatar
Question In channel Visor problems
So I recently purchased the Putco in channel visors for my 07 Hummer H3 and before purchase, like always, I researched and found that many people had problems installing them and the front windows hitting them. Well I just installed the complete set and installation was a breeze. BUT....... I don't have a problem with the front windows, actually the rear windows are hitting the visor and will not go up all the way unless I push on the outside of the window. Any suggestions or solutions.
Old Jan 27, 2013 | 07:16 AM
ozark1's Avatar
Best Solution....return them and buy WeatherTech...
Old Jan 28, 2013 | 07:06 AM
ceverts001's Avatar
[QUOTE=ozark1;292103]Best Solution....return them and buy WeatherTech...[/QUOTE
why does everyone think weather tech is the best solution? from experience they are definitely NOT the best solution... I have had weather tech visors blow off and crack. best solution to weather tech is putco and I am just looking for the solution to have them fit properly and not replace them with another brand. the brand isn't the issue, rather tips to install. but thanks for your reply.
Old Jan 28, 2013 | 07:42 AM
ozark1's Avatar
"If they don't fit...you must..............."
Old Jan 28, 2013 | 12:53 PM
NJTEX's Avatar
What about using a file to slightly ramp the area on the visor where the window first hits it?
Softening the visor with a heat gun and opening up the angle of the flange in that area a bit might work too.
Old Jan 28, 2013 | 01:26 PM
Old Yeller's Avatar
Push in on the window like you said you have to. Keep the window rolled up for a week that way the visor is really able to conform to the frame. Then try again. Also I have read that the putco visors for the rear are mislabeled and the right actually goes on the left and vise versa.
Old Jan 28, 2013 | 06:34 PM
RGray711's Avatar
Yes yes and yes worked for me.
Old Jan 29, 2013 | 04:50 AM
ceverts001's Avatar
thanks guys for the input. I installed the about 3 days ago and haven't rolled the windows down since, but its been cold and today is supposed to be high of 65..... in January.... so after a little direct sunlight and a little warmer weather I will give it a try. and I didnt see markings for left or right but they didn't seem to fit right the otherway so I think...am pretty sure I have them in the right sides. I think I may do the file trick as well even if they don't hit just becuz that sounds like a good idea either way. again thanks so much.
Old Jan 29, 2013 | 08:06 PM
ozark1's Avatar
PS..Carpe DiEm..
RutDogg
Aug 1, 2007 06:52 PM
RutDogg
Jul 26, 2007 03:20 PM
RutDogg
Feb 20, 2007 09:48 PM
azz7772
22
Jan 30, 2007 03:32 AM
blackstangs281
18
Oct 11, 2006 04:02 PM
