change oil light
Old Jun 30, 2017 | 03:20 PM
happythree's Avatar
Default change oil light
will not go out.tried my instruction book and 15 different button pushes.
it wont go away
what am i missing??
Old Jun 30, 2017 | 05:29 PM
Never seen a change oil light. H3s have a CHANGE OIL scroll on the DIC.
Oil light is totally different and usually not good.
Old Jun 30, 2017 | 09:24 PM
happythree's Avatar
Default explained message, not a light!
what i mean is i got a message that i need to change oil. the message shows up on the dic as words, "change oil". after changing oil i attempted to clear the message as described in my h3 instruction book.
i cannot clear the message,"change oil"
i tried every thing the book says, sounds simple but has no effect. im sure its something simple!! that im missing. i dont do it often..
i should have said, the message"change oil', LIGHTS UP on my dash display..
Old Jul 1, 2017 | 02:19 AM
scoreh3's Avatar
There must be something wrong , because mine resets really easy .
Old Jul 1, 2017 | 10:21 AM
happythree's Avatar
ok, pls tell me just what you do ok?
Old Jul 1, 2017 | 02:41 PM
happythree's Avatar
Default got it
by accident. need to put a note in my book,,,never happen!!
see you in 5000 miles!
Old Jul 1, 2017 | 06:52 PM
RKSmith163's Avatar
Close your doors, turn the ignition on and depress the accelerator 3 times quickly. It's not in the book but it works.
Old Jul 5, 2017 | 10:29 AM
Give the man a prize..... ding, ding, ding... CORRECT!
Old Jul 6, 2017 | 02:47 AM
Gomer's Avatar
Or like in my 2006 do this:
Remember to reset the oil life system whenever the oil and filter is changed.
1. Turn the ignition to RUN with the engine OFF.
2. Press and release the reset button in the driver information center (DIC) until the OIL LIFE message is displayed.
3. Once the alternating OIL LIFE and RESET messages appear on the DIC display, press and hold the reset stem until several beeps sound. This confirms the OIL LIFE system has been reset.
4. Turn the key to lock. If the CHANGE OIL message comes back on when you start the engine, the ENGINE OIL LIFE system has not reset. Repeat the procedure
Just make sure you hear all the beeps.
Old Jul 6, 2017 | 02:38 PM
BruceS's Avatar
I have an 07 and same process. Accelerator pedal trick does not work on mine.
