Can Stainless Steel be Powdercoated?
Old Feb 18, 2008 | 03:44 PM
solarflare's Avatar
Default Can Stainless Steel be Powdercoated?
I love my brushguard, that I bought from Hunter Truck Wholesale, but it has already decided to rust...really nice stainless steel...[:@][:@][:@]
I'm in the process of sending a nice email to them right now......if they do not do anything I would like to know if it is possible to powder coat stainless steel? and if there is any special process I will have to go through?
Old Feb 18, 2008 | 04:17 PM
blackbear's Avatar
Default RE: Can Stainless Steel be Powdercoated?
Yes you can powder coat SS, if it is really stainless steel they used, then whats happening is they did not passivate the stainless properly, passivation is a process where it removes all impurities from the stainless. One quick test you can do to know if it is SS is see if a magnet sticks to it, if it does, it's not SS or very bad quality.
Old Feb 21, 2008 | 02:19 PM
TheGunnyRet's Avatar
ORIGINAL: blackbear
Blackbear is correct, though from your pic it looks chromed? So I bet its steel.
Old Feb 21, 2008 | 02:45 PM
Muddydawg75's Avatar
it will be easier to take care of once it's powder coated too...
Old Feb 21, 2008 | 03:29 PM
solarflare's Avatar
magnet test: it will not stick.....so I'm assuming it's stainless, but really cheap stainless.....
I'm not sure if I should try to powder coat it myself or bring it to a shop......how much would a shop charge? I just need an idea on the price. I can do the side pieces myself, but I don't have a big enough oven to bake the center section.......
Old Feb 21, 2008 | 03:31 PM
vilim12's Avatar
they wanted 20 bucks for a gas cap, so im guessing somewhere arond 100-150
Old Feb 21, 2008 | 03:39 PM
Trey124's Avatar
You should get it coated, I have the Chrome Package and I bought the Black Brush Guard, the contrast between the two really makes it standout.
Old Feb 21, 2008 | 05:49 PM
blackbear's Avatar
ORIGINAL: solarflare
Does the manufacture say it stainless? if the magnet doesn't stick that's a good thing.
If it is stainless youcan use this to clean the brushguard.
Stainless Steel Cleaning and Restoring Gel
Also known as pickling gel, this gel safely removes weld scale, discoloration, and black oxides and other impurities from stainless steel without damage. Also restores the corrosion-resistant chromium layer to stainless steel. Apply gel directly to surface; no mixing required.
1-Quart Jar 8554T11Each $47.27http://www.mcmaster.com/
joeski01
Oct 6, 2007 12:01 AM
loglop
Sep 20, 2007 10:04 PM
machines
Feb 25, 2007 10:37 PM
RutDogg
Feb 16, 2007 01:30 AM
zibby
Aug 15, 2006 04:41 PM
