Can I get better MPG with synthetic in the entire drive train?
Old Jan 4, 2008 | 11:48 AM
TheGunnyRet's Avatar
Default RE: Can I get better MPG with synthetic in the entire drive train?
ORIGINAL: Desert Dan
I would say you would see more improvement in MPG by increasing air pressure in your tires (rough ride)and by keeping speeds below 70 MPH (hard to do)
This is a fallacy and is very unsafe, with the increased pressure and when your tires heat up your blow out possibility is imminent.
Doc, thanks for the reference site.
Old Jan 4, 2008 | 11:59 AM
NOMOYELLO's Avatar
HEY BOOBOO!The best way to maximize MPGs in your H3s----Add a K&N,some BIG OL TIRES and use a FEATHER FOOT on the throttle. ps:YOU ARE WASTING YOUR TIME.THIS IS A HUMMER YOU ARE TALKING ABOUT.
Old Jan 4, 2008 | 10:47 PM
tomp's Avatar
ORIGINAL: TheGunnyRet
What are you talking about? DD is 100% in what he said!
Old Jan 5, 2008 | 05:55 AM
ORIGINAL: tomp
Do you over inflate your tires, wear out the center part of your tread, cringe every time you hit a bump. If YOU do! more power to you. I don't its dumb, costly and not safe.
I would never recommend someone to do something that I wouldn't do that's dangerous. Ifyou are that type of person then I hope it never comes back at you.
Old Jan 5, 2008 | 09:19 PM
tomp's Avatar
No one said anything about over-inflating the damn tires Bro. Read the sidewall, as most hummer tires can safely handle much more air than the average person drives on. My Mickey Thompson tires say max pressue is 60psi on the sidewall. Are you telling me that you air up you tires up this high on a daily basis and you wouldnt have any room to go any higher?
Old Jan 6, 2008 | 02:00 AM
And no I don't air up with higher PSI, I keep it at the recommended psi as noted on the door plate. What I meant was you recommended it and do you do it. I don't.
Plus it doesn't do anything negligible to increase MPG anyway. I don't want to get into a pi$$$$ing contest.
The real problem is, they bought a Alpha and want the mileage of a Yaris by doing what they can to it. They should have gotton the I-5.
Forsche
Nov 15, 2012 08:14 AM
cdodson303
Feb 28, 2011 11:54 PM
luda81
Dec 26, 2009 08:09 AM
hummer3
Jun 17, 2008 07:07 AM
xLusi0n
Aug 20, 2006 12:45 AM
