Can anyone help with tire?
Old Aug 23, 2011 | 05:29 PM
fireman937's Avatar
Default Can anyone help with tire?
I am looking for 1 general grabber at2 305/70/16. I bought 4 about 8 months ago which is all the dealer had in stock not knowing that no one now has them. I have called general and they aren't making them right now. Does anyone know of someone or someplace I can find one. I am even considering buying used one from someone as long as it is in good shape. Just need it for spare. I have 08 H3. I have been looking since march.
Old Aug 23, 2011 | 06:06 PM
ava327's Avatar
If all fails get a bfg a/t almos similar tread
Old Aug 23, 2011 | 06:13 PM
SundownAudioNY's Avatar
Were are you located? We can get General and I know they had 315's in stock when I was looking up tires for a customer last week. I am not sure about the 305's but I can check tomarrow morning when I get to work.
Old Aug 23, 2011 | 07:47 PM
fireman937's Avatar
I am located in WV. I had another dealer today call General and they said they were still not making them and they gave no date to when they would resume. So it would be okay possibly to go with different make of tire as long as it is similar tread.
Old Aug 23, 2011 | 08:03 PM
skeptic's Avatar
For just a spare, pretty much any AT of the same size will be fine. Like ava327 said, the tread pattern is very similar to BFG AT/KOs if you are trying to match them as close as you can..
Old Aug 24, 2011 | 08:18 AM
Just checked with our vendor and they are out of stock. Must be just that size because they have plenty of the 285's and 315's in stock. For a spare you will be fine with another tire in the same size. Maybe pick up something used until they resume production.
Old Aug 24, 2011 | 03:27 PM
Bunger's Avatar
A 285/75/16 tire would be the same diameter. It would be OK as a spare.
Old Aug 24, 2011 | 03:41 PM
It would be OK but keep in mind the added width of a 305 on a narrow rim will affect the height. They measure the same height when the 285 is mounted on a 8" wide rim and the 305 is mounted on a 9" rim.
Again it should be fine for a spare but with it being AWD, I would keep it to an absolute minimum. Meaning only using it to drive on to get the tire fixed or replaced.
mullynyc
Sep 7, 2012 08:22 AM
luxh3
Mar 18, 2011 05:32 AM
luxh3
Mar 16, 2011 03:10 AM
jstdoitt21
Aug 22, 2009 10:21 PM
H2AMAN
Aug 18, 2007 04:33 PM
