A/C H3T Alpha 2009
Old Jul 21, 2023 | 11:18 AM
H3Tcanesnation's Avatar
Default A/C H3T Alpha 2009
Always had A/C issues and now its summer in florida again. Problem my A/C stop blowimg cold when the engine heats up. The temperature gauge in the rearview mirror slowly rises to 115 and the A/C air get warmer and warmer. I had my Aamco guy replace condenser and compressor with barely some change. At night my A/C work wonderful while driving but at idle again the temperature rise and the air get warmer and warmer. Any advise?
Old Jul 26, 2023 | 01:09 PM
Have you had the HVAC recall performed?
Old Jul 26, 2023 | 01:17 PM
Yes, I replaced the resistor(2019) myself. Original resistor wasnt burned but I thought it would fixed the issue.
Old Jul 26, 2023 | 06:01 PM
Clean the Evaporator Core/Air Temperature Sensor.
Old Jul 26, 2023 | 08:03 PM
echopark's Avatar
Could just be too hot outside. Both my 3 and 3t struggle when it is over 96°. But it’s fine below that. Same for my bmw. My brothers Toyota tundra is fine until 102
Old Jul 26, 2023 | 08:37 PM
I hear you, but at night (cool temperature 78) AC works fine but soon as my engine heats up and im not in motion, The rearview mirror temp starts rising (118 highest ever) and the AC blows warm air. If I take it for a spin the temperature drops and the AC air gets colder. Then repeats symptoms when im sitting in idle. Im going to clean or replace this evaporator sensor and go from there. For me it just seems like my engine is getting to hot and some how its kills the AC. I’m in the medical field, do beat me up to bad if thats not possible . (Alpha doesn’t run hot though from instrument reader)
Old Jul 26, 2023 | 08:49 PM
echopark's Avatar
Awh yes. What you described here my H3T does as well to an extent. When idling in the heat the temperature outside display will go up higher than the actual temp. Say it's 88 outside it'll read 95 until I drive it then it'll come back down to the actual temp. AC doesn't cool as well in those moments too until a drive. I don't have time to actually remedy this for myself but at my mileage I would imagine it could be a failing thermostat (I've already replaced the radiator). Let us know if you do fix it!
Old Jul 26, 2023 | 09:09 PM
Will do appreciate the help from the community
Old Jul 31, 2023 | 12:29 PM
If the PCM turned off your AC because of cooling heat your DIC would display "AC OFF". Check the pressure of refrigerant and add more to the Low side if necessary.
Old Jul 31, 2023 | 02:16 PM
I have never got the AC OFF display Doc. Just got the sensors in, Evac (15896238) & Air Ambient (25775833). Where is the Evac sensor located?
