Buying Parts - whatcha Think???
Old Nov 30, 2014 | 02:17 PM
jsbihn's Avatar
Default Buying Parts - whatcha Think???
Hey all,
I am curious if anyone has experiences with any of the following products.... or could possibly recommend something else.
I am not looking so much as for performance as for quality, BUT if you happen to know of a HiPo that would be better and for the same cash..... well.....
front hub/bearing assembly - Timkin
platinum spark plugs - Bosch O.E. Type
ignition wires - Taylor 8mm, B&B 8mm, Bosch 09017 Premium
rear springs (replacing the bags and compressor) - OEM Springs, Touring Tech, Arnott Set
lifting setup - McBay Performance, Supreme Suspensions (keys in front and spacers in back - additional question: with a 3 inch lift will I require longer shocks? I heard no from other forum members, but I want to make sure since the ad says yes)
belt tensioner - ??? OEM, Dayco, AC Delco, Dorman..... ???
air filter - OEM, Fram, Wix
Whatcha think?
Thanks in advance
Old Nov 30, 2014 | 10:46 PM
H2Miami's Avatar
Hubs - Timken
shocks and steering damper -Bilstein
Filter - Oem ( read post about Airaid filter)
I dont remember what spark plug I used
cant help with rear suspension
Old Dec 1, 2014 | 09:58 AM
calif phil's Avatar
Tensioner OEM or AC Delco.
Arnott makes nice products.
Old Dec 1, 2014 | 12:01 PM
khanson.82's Avatar
I would stick with AC Delco(OEM) spark plugs and wires.
Lots of stories around here of others being problematic..I replaced mine due to bad idle at 85K and they were bosch giving me the problems, someone before me had removed ac delco ones..
Thanks,
Old Dec 5, 2014 | 12:27 PM
hmer's Avatar
JSBIHN i just replaced my tensioner not too long ago and for a quick fix i went with a weird brand that 2 other friends (hummer drivers) had used before and so far its holding up good , by the way i got this part from oreillys .
Old Dec 6, 2014 | 07:59 AM
calif phil's Avatar
Gates is not a weird brand. They make some of the best belts and hoses you can buy,
Man1nboat
Nov 5, 2013 09:48 PM
Mcpousnret
Mar 22, 2013 12:04 PM
Wayne Auto Ebay
Aug 23, 2012 08:55 AM
bigdog100
Aug 19, 2010 09:30 PM
4reyes
Dec 2, 2008 06:55 PM
