Buying an H3
Old Feb 4, 2018 | 02:13 PM
Vin_E33's Avatar
Default Buying an H3
I’m looking at a 2006 h3 with 117,269 miles. The carfax shows a single owner and all maintenance was done at the dealership even the battery change. Is there anything in particular I should watch out for with a high mileage h3? On paper it looks real good
Old Feb 10, 2018 | 10:12 PM
hummer_on_fumes's Avatar
Check the radiator over for cracks and leaks. My radiator leaked internally which killed my transmission, seems to be a a dumb design, if you buy it, install a separate trans cooler and bypass the radiator
Another common issue are the drain tubes getting clogged if it has a moonroof, but you won't know that until it rains, there is a fix by cutting X's into the tube exits
You'll most likely have to replace the bulbs in the master switch and hvac controls as they burn out around this age
simian
24
Aug 16, 2006 01:39 AM
mln2963
Jun 18, 2006 12:56 AM
Hunter1
May 14, 2006 12:06 AM
dilo2001gt
May 9, 2006 09:39 AM
hummernewbie
Nov 24, 2005 09:39 PM
