Broken Coil Bolt
Old May 17, 2018 | 06:11 PM
Mikvi's Avatar
Default Broken Coil Bolt
I was replacing coils and one of the bolts snapped off flush. Does the bolt screw into the intake? Just trying to figure out how much of a job to fix this problem. The plugs were original after 160,000 miles and the truck came from Ohion, some soem corrosion problems
Old May 18, 2018 | 02:37 PM
Welcome to HF.
The I5 intake manifold is the black plastic box to the right of the Throttle Body. #500 below.
The Coil On Plug Pack bolts screw into the top of the head. #518 in the bottom diagram/
Google how to remove broken engine bolts. You can use extractors and other methods.
Old May 18, 2018 | 05:23 PM
Happy Hummer's Avatar
Well that sucks for you big time. I'd figure your going to need to drill and easy out or weld a washer to it and then a nut to the washer. Or conversely pay a place to do it for you. Sorry!
Chimpy
Apr 18, 2017 11:50 AM
SwillRacer
Apr 30, 2016 05:59 PM
bruceg
20
May 27, 2013 11:03 PM
sagev
Jan 17, 2013 11:41 AM
nyff395
Feb 28, 2012 09:17 AM
