brakes grinding again
Old Feb 9, 2008 | 01:09 PM
boomer's Avatar
Default brakes grinding again
i know this has happened to alot of us,with5000 mls brakes started grinding at hard braking brougt truck in and manager said that stones are getting caught in roters. refaced roters and everything was fine untill last week when brakes started grinding again. called dealer and they said thier was nothing they could do, that brakes were fine but will grind under hard braking because the pads they use are very hard. doesnt sound right to me,what does everyone think
Old Feb 9, 2008 | 02:21 PM
rhill20's Avatar
Default RE: brakes grinding again
Couldn't tell you, I've never had that problem and I have a real bad habit of braking late and hard. (just doesn't sound right, does it?)
Old Feb 9, 2008 | 05:28 PM
Your brakes shouldn't grind unless the pads are shot. They may squeal some if you haven't been driving much our it sits long enough to form a layer of surface rust on the rotor. Is there another dealer in the area you can take it to? Your dealer's answer isn't the right one.
Old Feb 10, 2008 | 02:13 AM
Significant's Avatar
just to let you know there is a bulletin on this problem... the stones getting caught in the rotors/pads is a bs story... if it is coming from the rear then take your car back to the dealership and tell them to look up the bulletin... i cant exactly remember what the name and the number was... but some h3s came with bad rear brake rotors that need to be resurfaced... i remember because i just did one this week... its described as a grinding, grunt, squeaking sound...
Old Feb 11, 2008 | 10:32 AM
RealJeep's Avatar
TRUE...Someone else has posted this TSB on here before. Do a search and you'll find your answer.
Old Feb 11, 2008 | 11:36 AM
TheGunnyRet's Avatar
Here it is from what Doc posted.
https://www.hummerforums.com/m_94164/tm.htm
Old Apr 30, 2008 | 11:56 AM
RealJeep's Avatar
I just got my H3 back today from HUMMER and here's what they did to fix the brake vibration problem. I'll have to let y'all know how long it lasts.
Customer states vibration on hard braking:
Found: glazed rear brake pads, replaced with "ceramic compound pads" Part Number 19165360 Pad Kit 5.017
Old Apr 30, 2008 | 08:17 PM
hummer's Avatar
Is this what makes the truck sound like its farting when you brake hard?
Old Apr 30, 2008 | 08:23 PM
rhill20's Avatar
ORIGINAL: hummer
That sounds like a personal problem[8D]
Never heard that before, no noises from braking.
Old Apr 30, 2008 | 08:32 PM
hummer's Avatar
ORIGINAL: rhill20
ORIGINAL: hummer
When I but on my brakes hard, right before the truck stops completelyit makes a noise from the back that sounds just like a big fart!
