Body Lift
Old Dec 7, 2016 | 10:32 AM
Gdraft's Avatar
Default Body Lift
So I am looking at a 3 inch body lift, will be doing it myself. Has anyone done it and if so, what are my considerations? Thanks
Old Dec 7, 2016 | 12:44 PM
You can get away with 1" without any significant modifications.
3" will require review of Trans linkage, brake lines and ABS wiring, radiator hoses (the upper will have to be replaced for sure) and trans cooler lines, stock air intake, wiring for lights (signals, running and headlights are probably OK) and other chassis wiring, like for the trailer plug.
Old Dec 7, 2016 | 01:21 PM
Bunger's Avatar
You will have to address the steering shaft linkage too.
3" body lift is not really a good idea. 1" is easy, 2" is iffy.
Old Dec 16, 2016 | 04:38 PM
Gdraft's Avatar
I'm not sure a1 inch is enough, I just put 35 inch tires on 20 inch rims and rubs in front. Maybe a 2 inch lift. Has anyone done a 2 inch lift and are there pictures? Thx
Old Dec 17, 2016 | 06:46 AM
The offset of the rims may be the issue, not the lift.
Old Dec 18, 2016 | 11:00 AM
650Hawk's Avatar
Yup. 35's will fit with no lift at all. Your rims are likely the problem.
Old Dec 19, 2016 | 08:11 PM
Gdraft's Avatar
I hadn't thought about that, my rims are pretty offset, not sure the exact dimensions of the offset
Old Dec 20, 2016 | 07:40 AM
Take one off and measure the backspacing.
Plenty of info on how to do it on the web.
jake1z
Jan 29, 2013 04:44 AM
CyrusPaice
Hummer H3T
May 23, 2010 10:11 PM
dalandshark5
Jan 4, 2010 02:04 AM
fsr7
24
Dec 12, 2009 02:40 PM
waynesoffroad
Sep 21, 2007 01:12 PM
