Blowing Fuses
Old Feb 4, 2009 | 03:55 PM
Keithmo's Avatar
Unhappy Blowing Fuses
I seem to be blowing fuses to my cruise control/Rear view Mirror. Anyone had this problem or ideas where to look to fix it. Thanks.
Old Feb 4, 2009 | 08:44 PM
lucky19942001's Avatar
no issues here u can try a bigger fuse and see what that does and if that dont work maybe a short some where. i would try the fuse and if nothing i would go to the dealer but mine is under warranty good luk
Old Feb 7, 2009 | 10:25 PM
Keithmo's Avatar
Well I found my problem. Previous owner installed a portable gps, and hard wired the power cord by snipping about 3" off the power cable and splicing that to speaker wire. He ran than in the gheadliner then down behind the dash to a power block behind the emergency brake lever. The break lever wore on the wire and there was my short. The dealership informed me that after vmarket work invalidated the warrenty and taking down the headliner will be $300.00. Took to a local car audio shop and the cost was $11.00. Caught a deal for a change
Old Feb 7, 2009 | 10:37 PM
$300 what a rip. i took mine down myself in about 10 min to install clearance lights, $11 u cant beat that and why would u run to speaker for power. not the first place i would look but maybe it worked for them cause there must of been no issues until the wire got thin,glad u fixed the problem
Old Jun 24, 2014 | 07:46 PM
Crawler guy's Avatar
Default Got an 06 Hummer H3 blowing fuses after taking it out of drive
My Hummer H3 starting blowing fuses after I rinsed the engine compartment off. After that it started blowing fuses. This has been like 2 weeks ago. Still blowing fuses. I've checked all the connectors. They all seem dry. It will start and run. But as soon as you take it out of drive, it cuts off and blows the ignition fuse. Has anyone had this problem?
Old Jun 25, 2014 | 07:44 AM
happythree's Avatar
after pulling the coils and plugs and drying them and putting a heater / fan on top to dry it out i 'd not wash the motor with water any more. not a good thing...thats why they put hoods and rubber seals in there ya know..
solarflare
Oct 4, 2011 11:19 AM
MPWR99
May 3, 2009 09:42 AM
wrbrackett
Sep 24, 2008 01:44 AM
SafariHummerH2
Jun 8, 2008 07:55 PM
arichie
Oct 22, 2007 05:16 AM
