Blistein shocks
Old Feb 7, 2016 | 10:49 AM
mcioci's Avatar
Default Blistein shocks
I put the 5100's in my 05 and want to buy them for my 2003 h2. My truck is lifted but I don't know how much since I bought it after the lift. Anyway I measured the existing shocks and he fronts are about 15' measures to middle of both top and bottom bolts. The rears are 23' measures same way. Can someone tell me what numbers I should be looking to get with shock extended and collapsed?
Old Feb 9, 2016 | 01:14 PM
H2CANEPADESIGN's Avatar
You can go directly to bilsteins website. Bilstein, Innovation and High Quality Since 1873 they list different options for the different ride heights you may have. your going to have to figure out how much of a lift is on your rig though. also once you get the correct part #s check amazon. they usually have better prices than anyone else.
Old Feb 9, 2016 | 10:17 PM
yrkdmaxh2's Avatar
I bought some bilsteins a while back from the shockwarehouse for my lifted WJ jeep. They were the lease expensive, but this was before amazon became so popular. Like I said a while back haha. Worth checking into though
Old Feb 10, 2016 | 07:35 AM
mcioci's Avatar
I will call Blistein and pick their brains. Thx
Old Feb 10, 2016 | 09:01 AM
yrkdmaxh2's Avatar
If you go to the Bilstein website and put in your vehicle it will give you the shock dimensions.
Yours sounds like you should be able to use the stock up to 2.5" lift one iirc.
Old Feb 10, 2016 | 02:35 PM
mcioci's Avatar
Looks like Blistein doesn't make a rear shock for my truck. They said the ones they have are either too small or way too long. The fronts would fit but not sure I want to have diff shocks in front and rear. Anyone have any experience with the new Skyjacker M95 series shocks?
Old Feb 10, 2016 | 06:13 PM
yrkdmaxh2's Avatar
I could be wrong but these should work.
Part Number: 25-187625
Series: 5160 Series
Position: Rear
Front Spring Type: Torsion Bar
Rear Spring Type: Coil
Descriptor: Rear Lifted Height: 0-2"
Collapsed Length (IN): 16.14
Extended Length (IN): 27.17
Collapsed Length (MM): 410
Extended Length (MM): 690
Old Part Number: F4-BR5-G714-H0
Your 23" length is right in the middle.
Old Feb 11, 2016 | 07:22 AM
mcioci's Avatar
Series: 5160 Series
Position: Rear
I was looking for the 5100 model. The 5160 are very expensive and not looking to spend that much on shocks. I may go with the 5100 for the front and skyjacker m95 for rear. Thanks for the info though.
Old Feb 11, 2016 | 07:43 AM
yrkdmaxh2's Avatar
No problem
They are a little pricey
Old Feb 11, 2016 | 09:22 AM
mcioci's Avatar
No problem
I like the Blistein 5100's and am considering putting them in the front and skyjacker M95's in rear. Do you think its better to put the skyjackers all the way around? I wouldn't think having Blisteins in front and skyjackers in rear would affect the ride of truck.
gdfthrschill
May 2, 2007 02:35 PM
shortbus
Dec 29, 2006 09:34 PM
dilo2001gt
21
Dec 6, 2006 09:40 PM
dilo2001gt
Nov 27, 2006 11:42 PM
dilo2001gt
Nov 13, 2006 05:19 PM
