Bcm
Old Nov 9, 2016 | 04:36 PM
Steve.in.Roanoke's Avatar
Unhappy Bcm
'06 H3. Stealership says BCM is stuck in "Learning Mode". Result, security light stays on & they want $680 for the module and say that's the only fix. Claim it won't affect operation or reliability.
Any suggestions? Or thoughts?
Old Nov 10, 2016 | 09:39 AM
Do you have a sunroof? Passenger side floor ever been wet?
a new BCM will cost just a tad over $200, but it has to be programmed to your vehicle. Go to a different dealership, or call around and get prices, any GM dealer can do it for you, IF that is the problem.
The security light may just be a Pass Lock problem, Google it.
Old Nov 10, 2016 | 11:15 PM
HUMTECH's Avatar
Ask them if they attempted a pass through theft learn with new keys. Its very possible the BCM is at fault but can also be due to incorrect programming. The system needs a correct key cut to send the ok message to bcm. If ignition keys are excessively worn it can send a invalid security code but its close enough to allow it to start. Pretty rare that that occurs but cheaper than a bcm. And yes it will continue to start and run in this mode but the flashing theft light gets annoying
Steve #1
Mar 30, 2019 03:49 PM
runamok
Oct 14, 2011 08:50 AM
vmif16
Jul 3, 2010 02:22 PM
hyposho
May 27, 2010 03:58 PM
07HummerH3
Jul 31, 2007 10:55 PM
