Battery issues- replaced two in last 2 years
I've got an 03 and it seems like every 6 mos. I come out to a dead battery. I think it is my ignition cylinder. Sometimes when I remove the key. The battery light on the dash stays illuminated. I have figured out that sometimes the key can be removed while the ignition cylinder isn't fully disengaged.
Can someone do me a favour and go out to their truck put the key in the ignition and turn it to start and then remove it. Does the battery light stay come on for a second and then go out? Just wondering if this is normal or the computer is telling me the battery is on the way out. Thanks |
You nailed it. If the battery light stays on you will kill your battery. My 03 had the same problem. A new switch will fix it. You need the electrical part of the ignition switch not the ignition lock cylinder.
Thanks calif phil.
