axle/gearing/lift questions
Old Dec 31, 2006 | 02:07 AM
rsm688's Avatar
Default axle/gearing/lift questions
first off, what axles do the h3's have? what's the max tire that can be run on the stock axles? what gearing is in the stock axles? anyone had any problems with a lift yet?
i know these are newbie questions but i dont own a h3 im just very heavily considering purchasing one and i would like to get the kinks worked out before i do
thanks,
spencer
Old Dec 31, 2006 | 02:10 AM
importkiller's Avatar
Default RE: axle/gearing/lift questions
35's fit stock with no lift and no gearing mods needed. I know of one guy with a 4" lift and 37's with stock gearing also, but I wouldn't recommend that his off the line torque blows.
Old Dec 31, 2006 | 02:13 PM
BahamaTodd's Avatar
So what gear ratios are available? I know for the first couple of years it was 4.10s with the 32s and 4.56s with the 33s. Has that changed recently? I cant find anything about 4.10s being available, only 4.56s.
Old Dec 31, 2006 | 04:03 PM
rsm688's Avatar
how do the axles handle 35s and 37s off road? anyone know what axles are under it? so im assuming the off road package has 4.56s right? are lower gears available like 4.88s or 5.13s? how do the 35s affect top speed and acceleration?
thanks,
spencer
Old Dec 31, 2006 | 04:21 PM
wow, thats alot of questions....35's on stock axle gearings have made it through the rubicon multiple times, moab, paragon and have never had a problem.Axle gearing is the same on both the adventure package and the base package, only difference between the two is a locking rear diff and the t-case. Top speed has not been affected with my 35,s I still average 80+ on highway. Acceleration seems the same also, was never that good to begin with.
Old Dec 31, 2006 | 05:13 PM
BahamaTodd's Avatar
Not sure if they're the same, but the Colorado has an American Axle 8" axle in the rear. Top speed should be higher if you dont reprogram your pcm. Even though your speed limiter would kick in when your speedo read 98, the larger tires (37s for example) would actually have you going about 110mph. The PCM tune (which you should get when you get the large tires anyway) can remove the speed limiter all together if you want.
When did they go to only offering 4.56s?
Old Dec 31, 2006 | 05:24 PM
Ghostrider's Avatar
The adventure pkg also has a 4.03:1 t-case as opposed to a 2.64:1 std.
Old Dec 31, 2006 | 05:28 PM
thats what I meant when I said differetn t-case, just didn't feel like typing it again
and yes teh rear gear is a 4.56:1
Old Dec 31, 2006 | 05:47 PM
Ghostrider's Avatar
Oh yea you did mention that! I didnt see it! "my bad"
Old Dec 31, 2006 | 06:35 PM
not at all bro, just glad you types the numbers...I'm too lazy today
