Avic-900
Old Feb 13, 2009 | 06:48 AM
aczech's Avatar
Default Avic-900
Hello all,
Just recently installed and when I go from Acc to off, the radio seeks down. What went wrong?
Old Mar 11, 2009 | 10:31 PM
cyborg136's Avatar
can you post some picture of the unit. Was it a perfect fit? Did you also opt for the XM receiver and how did it fit or where did you install it.
Thanks.
Old Mar 13, 2009 | 08:32 AM
Lauxmi01's Avatar
I have the pioneer 9010bt as well, I have a sirius radio hooked up to it, but my H3 is also manual, and the accessories for the radio are tucked in under the dash, through the shifter boot. Also, my GPS antenna / sirius antenna were able to fit under the trim for the marker lights for a clean install. I will update with pics shortly.
Old Mar 14, 2009 | 11:56 AM
cyborg136's Avatar
Thanks. After a long debate I opted for the Pionieer Avic N-5 as it needs a single slot only and the display will be higher if I put it in the upper slot. The other slot should provide space for the XM and Bluetooth unit. I will start to work on it next weekend when I have all pieces.
What adapter did you use to retain your Onstar etc.
PostRelease
Jun 17, 2009 03:24 PM
PostRelease
PostRelease
PostRelease
jaydcc69
Apr 13, 2008 02:29 PM
