AUDIOBAHN A2300HCJ 4800 watt amp and 2 Audiobahn AW1200J subwoofers
Old Mar 6, 2013 | 12:39 PM
groomsxxx's Avatar
Default AUDIOBAHN A2300HCJ 4800 watt amp and 2 Audiobahn AW1200J subwoofers
Brand new AUDIOBAHN A2300HCJ 2 channel 4200 watt amp
General Features:
2-Channel Class AB High Current Car Amplifier
RMS Power Rating:
4 ohms (Stereo): 450 watts x 2 chan.
2 ohms (Stereo): 700 watts x 2 chan.
1 ohm (Stereo): 1000 watts x 2 chan.
4 ohm (Mono): 600 watts x 1 chan.
2 ohm (Mono): 1200 watts x 1 chan.
1 ohm (Mono): 2400 watts x 1 chan.
PWM MOSFET power supply
Large display volt meter with blue illumination
Variable Bass Boost (0-18 dB)
High gloss chrome-plated finish
2-Channel operation
Throughput RCA connections
Cobalt blue illumination
Double-Sided glass epoxy circuit board
Dual cooling fans help to maintain its optimum operating temperature
Chrome flame fan grilles for an enhanced appearance
4-Way Protection Circuitry: Thermal, Short Circuit, Overload , and DC Offset
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Nickel-Plated RCA level inputs
Nickel-Plated block terminals
Input Sensitivity: 200mV-8V
Variable Low-Pass Filter (30-120 Hz, 24 dB/octave)
Variable High-Pass Filter (50-750 Hz, 24 dB/octave)
Subsonic Filter (20-45 Hz)
Frequency Response: 10-20,000 Hz
Signal-To-Noise Ratio: >100 dB
Dimensions: 25-5/8"L x 11-15/16"W x 2-1/2"H
Brand new Audiobahn AW1200J 12" Dual 4 ohm High Excursion Series Car Subwoofer (2)
12" High Excursion Series Subwoofer
Power Handling
RMS: 700 watts
Impedance: Dual 4 Ohm
High gloss high-strength carbon composite cone with laminated pulp reinforcement
Tall narrow foam surround increases cone surface area which means more air displacement
Can be installed in a sealed, ported or band pass enclosure
Cast aluminum flame design basket
Aluminum black anodized voice coil former for highly efficient thermal transfer
Extended pole piece provides a more linear magnetic field
Vented oversized back plate for high excursion
Flat spider design
3" Dual 4 Ohm voice coil
120 oz magnet
Multi-Connect lug lock terminals offer increased versatility in wiring multiple subwoofers
Operates in 2 or 8 ohm configurations
Frequency Response: 20-500 Hz
Efficiency: 94.65 dB
Mounting Depth: 5-5/8"
Hole Cut Out: 11-1/2"
Outer Diameter: 12-3/4"
Old Mar 14, 2013 | 07:19 PM
groomsxxx's Avatar
Bump!
Old Mar 14, 2013 | 09:32 PM
dr.drew2's Avatar
Default how much $$$$$$$$$$$$$$$$$$
So how much $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Old Mar 15, 2013 | 08:45 AM
groomsxxx's Avatar
$650 shipped in the usa
Old Mar 20, 2013 | 09:11 AM
groomsxxx's Avatar
bump!!
Old Mar 20, 2013 | 07:48 PM
dr.drew2's Avatar
how reliable are these . i know they are discontinued. were these bought and just never used.
Old Mar 21, 2013 | 08:52 AM
groomsxxx's Avatar
Very reliable brand. Great set up. Yes, they were bought for my car but never used and I don't want to put them in my hummer.
Old Mar 23, 2013 | 04:15 PM
groomsxxx's Avatar
Bump $650 shipped in the usa.
Old Mar 27, 2013 | 08:31 AM
groomsxxx's Avatar
Anyone here have any interest?
Old Mar 30, 2013 | 06:20 PM
dr.drew2's Avatar
Is that your best price??
