Assistance in Shock R&R
Old Sep 13, 2016 | 07:53 AM
OCFDfyrfytr's Avatar
Default Assistance in Shock R&R
Directions needed. RNR of rear shocks, non-airbag suspension, on my 2008 H2. Thanks...
Old Sep 13, 2016 | 01:44 PM
HUMTECH's Avatar
  1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle.
  2. Support the rear axle.
  1. Disconnect the air suspension level sensor (if equipped). Refer to Air Spring Leveling Sensor Replacement.
  2. Remove the upper shock absorber nut and the bolt.
  1. Remove the lower shock absorber nut and the bolt.
  1. Remove the shock absorber.
<a id="d2921e60">Installation Procedure
  1. [*]
  2. [*]
  3. [*]
  4. [*]
  5. [*]
  6. [*]
Old Sep 13, 2016 | 07:17 PM
hmm. the new shock expanded when i removed retaining strap. unable to compress to reduce length to fit lower bolt hole. Why support the rear end as well suppoting the vehicle? tU
Old Sep 14, 2016 | 08:00 AM
calif phil's Avatar
I cut the strap after the shock is loosely installed. You should be able to remove the shock and compress it with your body weight while someone slips a strap back on.
Old Sep 14, 2016 | 10:34 AM
Synthetickiller's Avatar
You need the clearance.
I didn't have anyone to help me do the rear swap. I just got under the vehicle & compressed it with one arm & shoved the bolt in as fast as possible. At least I can finally justify how bench pressing can be used in the real world, lol. That was a really, really frustrating endeavor!
Old Sep 14, 2016 | 01:52 PM
HUMTECH's Avatar
Yes you need to lift by the frame then support axle, one reason is for maximum clearance to install new shock the other is if you lift by frame and not support axle the rear axle will drop and the coil spring will come out.
Old Sep 15, 2016 | 11:57 AM
Sir thank you. You have been spot on in all of my recent endeavors
Old Sep 15, 2016 | 10:35 PM
flyday58's Avatar
I used a cargo strap to hold it in the compressed position, then cut the shipping strap. Name:  IMG_4637_zps9rff8fbs.jpg
evilred26
Jan 21, 2011 11:11 PM
machines
Mar 26, 2007 11:32 AM
HUMMERmole
Dec 5, 2006 11:40 PM
HummerGuy
Oct 25, 2006 08:58 PM
importkiller
Sep 12, 2006 04:01 PM
