Anyone else get a recall notice
Old Jun 2, 2009 | 05:37 PM
calif phil's Avatar
Water intrusion into the wiper module was the reason for the recall. I would bet that is your problem.
Old Jun 2, 2009 | 06:07 PM
pteam's Avatar
The speedometers not working in winter time which has happened to about 6 or 7 of my H2's is a much more major problem, and wasnt addressed for years. I dont know how this wasnt a massive major recall issue as this is seriously dangerous. They finally issued a recall a year or two ago. I havnt had the wiper issue with any of my H2's
Old Jun 4, 2009 | 09:08 AM
john1948's Avatar
Default Windshield washer motor always on
OK I pulled off the cover to the wiper motor and I see the circuit board, is the problem on with water on the reverse side of the board which I cannot get to, the motor facing side looks OK. Any suggestions
Old Jun 8, 2009 | 10:00 PM
taternation5831's Avatar
Default Free cover
They will put the cover on for free but the want $600 to replace the wiper motor and the wiper motor module if has been damaged
Old Jun 9, 2009 | 01:09 PM
john1948's Avatar
Default Hummer recall notice windshield wiper module
Any one have the VIN number sequence that covers this recall. I called my local Hummer dealersip and they said: there was no recall for my 2003 Hummer.
Old Jun 10, 2009 | 08:50 PM
Default lemonlaw.com
checkout lemonlaw.com
Old Jun 11, 2009 | 09:30 PM
bflorin's Avatar
that circuit board will pull straight up and out...dont remember if there were any screws, but I had it out in 5 minutes.
If you **** isn't working...I bet there are carbon tracks (you can't miss them) on the underside of the board twards the front of the vehicle... Scrape those tracks off...I had like a small wirebrush tooth brush... That will eliminate the short on the circuit. One you get everything cleaned off, smear electrical grease all over everything... You can't use to much.
unless you completely smoked something on that board, you should be Good to go.
Old Jun 12, 2009 | 12:14 PM
VegasGuy's Avatar
At the risk of stating the obvious, make that NON-conductive electrical grease.
Old Jun 12, 2009 | 08:40 PM
jono123's Avatar
i don't think like you
wet_rat
May 25, 2010 11:27 AM
2wheelmonster
May 17, 2010 12:42 PM
importkiller
38
Dec 2, 2006 02:37 AM
dilo2001gt
Jun 26, 2006 05:25 PM
dilo2001gt
Dec 27, 2005 01:43 AM
