Any one install a remote oil filter on H2?
Old Jun 6, 2012 | 05:03 PM
Rusty_03's Avatar
Default Any one install a remote oil filter on H2?
Have been planning on installing a remote oil filter on my H2 mainly to install a larger filter.
Has anyone done this? What block adapter did you use?
MikeH
Old Jun 6, 2012 | 05:34 PM
LoJac963's Avatar
I asked this same question a while back with no responses. I'm looking to relocate the filter for better access. I've only found one kit specific to the H2 but I know the block off plates are engine specific so really the options should be limitless. I just need to confirm the threads on the block....
Old Jun 6, 2012 | 07:43 PM
honda400ex2003's Avatar
im curious as to why you want to move it for better access? it is right there facing up, its by far the easiest GM engine filter i have came across to this point.
maybe im spoiled, i can just about sit straight up while doing my oil change without a jack or anything under it. lol
just curious,
steve
Old Jun 7, 2012 | 04:22 PM
Rusty_03's Avatar
Relocation is secondary. I just don't like the itty-bitty filter.
MikeH
Old Jun 7, 2012 | 06:28 PM
LoJac963's Avatar
Well all I have owned is GM vehicles my entire life and I can definitely tell you it is NOT the easiest filter to access.
At the same time I never said it was hard, it is in an awkward spot. If the frame/skidplate isn't cutting your hand/wrist up then oil is dripping all over the place. I want to move it for simple convenience of making oil changes that much easier.
Old Jun 7, 2012 | 09:18 PM
a bigger filter would be nice, you could in fact run a bigger one on it if you wanted to. just get one thats the same diameter and run a longer one. I had a longer one on mine when i changed my oil last weekend. i took it off and put the correct one back on.
maybe im missing a skidplate or something, i didnt have anything blocking my plug or access to my filter. it is a bit tight on one side but i got it off and back on in a couple of minutes.
i was just curious, both are good enough reasons to move it if possible.
steve
H2zona
Aug 6, 2018 06:31 PM
drtom
Jan 17, 2011 09:23 PM
LGK
Oct 3, 2010 04:09 PM
hummer07
Nov 18, 2008 10:46 AM
Brandon07
40
Jul 27, 2007 08:29 AM
