Alpha o2 simulators??
Old Dec 28, 2016 | 08:10 AM
alpha3's Avatar
Default Alpha o2 simulators??
im getting the p0420 code and tried the spark plug non foulers but the code still comes back with one and i get a p013b with 2 foulers.
anyone know where i could get a plug and play o2 simulator
Old Dec 28, 2016 | 11:07 AM
MOVED from the Drivetrain Area where it says: This section is an archive of older posts, please post new questions in the specific model section. Thank you!
Old Dec 28, 2016 | 11:19 AM
Now that we have your thread in the correct section, might want to re-think your approach. A P0420 can indicate more serious stuff going on than just using a cheap fake out to try to resolve it.
I would have it scanned and see what is going on and properly diagnose what the condition is before ignoring that potential problem. If it is indeed an 02 sensor, simple fix. Might need a new Cat. Could be worse. If it is just a glitch, your idea may be OK.
Good luck
Old Dec 28, 2016 | 11:35 PM
sycraft's Avatar
Old Dec 28, 2016 | 11:37 PM
sycraft's Avatar
B I G
D A D D I E S
G A R A G E
Mini cat o2 simulator
~~ Mini Cat O2 Sensor CEL FIX ~~
~ ~ See How It Works Below ~ ~
This Is Not A Mechanical O2-Sim Spacer...
~It's a "Mini Cat O2 Sensor CEL FIX"~
Get Rid Of That Cel...REMOVE P0420, P0430 Error Codes...The Right Way...See Cut Away Pictures Below...
Designed For High Performance Modified Catless Exhausts...
Turbo and Non-Turbo Engines...
1.6 thru 6.3 Litre...
40 CFR 1068.101 (4)(B)
Manufactured and Sold Expressly for Non-Road Vehicles Used Solely for Competition.
Racing, Modified Racing Exhaust Testing an Tuning Diagnostics ONLY.
Not sold For Use On Production Street Vehicles ("on road" or "on highway" vehicles)...
~~~ Part Number MC-CC-SSCF18 ~~~
Mini Cat O2 Sensor CEL FIX...Removes Your Cel, SES, or Mil Light...The Correct Way !!!
Do You Have a CEL, SES or MIL Light on...?
Do You Have a Test Pipe, Headers, High Flow Cat, Downpipe, Catless or High Performance Exhaust Installed?
Then This "Mini Cat O2 Sensor CEL FIX" is perfect for you and will get rid of those Annoying P0420 and P0430 Codes!
~ ~ ~ Universal Design FITS ~ ~ ~
BMW 3 5 7 Series M3 M5 Z4 M4... Audi A3 A4 A5 S3 S4 S5 RS4 TT TTS
Toyota Camry Scion xA xB xD tC ... Nissan 350Z G35 G37 300ZX S14 S13 240SX
VW Beetle Jetta GTI Golf R32 EOS Passat... Mazda 3 6 RX7 RX8 Miata MX3 MX6
Subaru Impreza WRX STI Legacy WRX... Mitsubishi EVO Evolution 8 9 10 Lancer...
Honda Accord Civic S2000 Integra S2 S2K... Chevy, Ford, GMC, Dodge, SUV & Pick Up Trucks
Mustang, Corvette, Lexus, Matrix, Tiburon, Viper, Abarth, Kia, Saab, Volvo, Altima, Maxima, Eclipse, Legacy, Baja...and more!!!
1996 thru 2016...Turbo and Non-Turbo Engines...
~ ~ ~ ~ See Below "SIZE...MATERIAL DETAILS" On How To Check Your O2 Sensor Thread Size. ~ ~ ~ ~
~~ HOW IT WORKS ~~
This Mini Cat O2 Sensor CEL FIX Works On The Same Principal as Your Larger Catalytic Converter...
Your Noxious Exhaust Gases are Oxidated and Converted By Passing Thru a Three Way Ceramic HoneyComb Element
Coated with Platinum, Rhodium and Palladium. The Noxious Exhaust Gases React Within the HoneyComb
and are Converted Into Carbon Dioxide and Water, It also Converts the the Nitogen Oxides back into Nitrogen and Oxygen.
Just What Your O2 Sensor Is Looking For...Resulting In Your CEL Being Removed.
99.9% of the time P0420 and P0430 CEL Error Codes Are Associated Only With The Post (rear) O2 Sensor in modified exhaust systems (in or after the cat). This sensor is also known as the 'Heated Sensor Circuit' or 'Bank 1 sensor 2'.
With a Modified Exhaust System, the Post Cat Sensor receives A Higher Exhaust Temperature and A Higher Exhaust Flow Unburn Rate than Stock Exhaust Systems. This causes the ECU to read that the exhaust system is out of balance. When the ECU sees that the system is out of balance it throw's a code and drops into 'limp mode' (safe mode). When you add this Mini Cat O2 CEL FIX onto the Post Cat O2 Sensor, it will Convert Noxious Exhaust Gases and send the ECU the expected exhaust reading, Just As It Expects.. Thus allowing your ECU to run Your Engine Optimally to Produce the Added Horsepower.
~~ INSTALLATION ~~
Get Rid Of That Cel...Remove the P0420 and P0430 Error Codes...
This Mini Cat O2 Sensor CEL FIX simply is screwed on to your existing O2 sensor and the assembly is replaced into the O2 bung.
Easier to install and more reliable than a Costly, Hard To Install Electrical Device! No Soldering or Splicing involved!
Takes less than 10 minutes to install this Mini Cat O2 Sensor CEL FIX, PLUS You can Remove it any Time You Want!
V8, V6 or Dual Exhausts... Will Need TWO (2)
~~ SIZE... MATERIAL DETAILS ~~
~~ MADE FROM PREMIUM QUALITY T 304 STAINLESS STEEL ~~
~~ NO RUSTING, NO SCALING, NO CORROSION, NO PITTING, NO BLISTERING, NO FLAKING, NO RUST STAINS ~~
This Mini Cat O2 Sensor CEL FIX is made entirely from T 304 Stainless Steel, It is not ZINC PLATED CARBON STEEL filled with Steel Wool like those sold by others on eBay. What you need to understand is that Zinc Plating begins to Blister and Flake at 320 degree's. Once this begins the Plating literally falls off, or Blacken's then it Immediatly begins to Rust. Your Exhaust System will reach and Exceed 620 degree's and Remain at this Temperature While in Operation. Your O2 Sensor begins operating at 600 Degree's and usually has a heated wire to reach this temperature quickly. Once the Zinc Plated Carbon Steel Adapters filled with Steel Wool rust inside your pipes, The Rust becomes Saturated with Exhaust Contaminates and once again you throw a Cel and go into open loop (limp mode).
THIS WILL NOT HAPPEN WITH This Mini Cat O2 Sensor CEL FIX! T 304 Stainless Steel will not rust and the Honeycomb elements with Platinum, Rhodium and Palladium coatings ACTUALLY CONVERT EXHAUST GASES...
Just like your Cars Full Size Catalytic Converter.
Made in America of T-304 Premium Stainless Steel.
Wrench Size 22MM (7/8")
Lenght 48MM (1 7/8")
Thread Size 18MM (11/16")
It is your responsiblity to check fitment and clearance issues, please check.
Check Your Size By Putting a 22MM (7/8) Open End Wrench Onto Your O2 Sensor, IF IT FITS...The Threads Are 18MM!!
~~ MINI CAT CEL FIX ~~
One (1) T 304 Stainless Steel Mini Cat O2 Sensor CEL FIX...PLUS One (1) Washer!
$49.95
FREE SHIPPING... U.S. and U.S. Territories
International Buyers, Click Here to add International shipping.
Please Note:
(1) This Does Not Fix A Defective O2 Sensor,
(2) No...O2 Sensor Is Included In This Offer.
(3) Designed For Post Cat Sensor ONLY.
(4) Intended For Off Road Modified Exhaust Use Only.
(5)Do Not Use To Remove Cel Caused By Faulty Catalytic Converter!
~~ Buy It Now with PayPal ~~
~~ For Same Day Shipment ~~
NOTE: SHIPPING:
1.This Item Is Delivered Via USPS First Class Mail, With Delivery Confirmation.
2. International Buyers, Click Here to add International shipping.
3. International orders can be subject to both delays and addional fee's, such as
import duties, import fee's, taxes, etc. assessed by Customs, the buyer is responsible for all such costs.
Big Daddies Garage is not responsible for delays caused by Customs allow 21 to 45 days for International delivery,
unless Guaranteed Delivery Service is used.
4.We will Ship your Item Same Day (except Sat., Sundays, Holidays) immediately after payment is complete using PayPal.
5. PAYPAL...We will Ship only to your confirmed PayPal Address, Please do not ask for delivery to another destination, We will not do it.
6. Refunds on Orders Not Yet Shipped or Ordered in Error, carry a 1.00 US$ refund processing fee.
7.This Racing Item Is NON-RETURNABLE.
~~BUY IT NOW...T 304 Stainless Steel Mini Cat O2 CEL FIX~~
~~COPYRIGHT 1996-2015 Big Daddies Garage, all rights reserved.
MINI CAT CEL FIX, The Very Best Cel Fix Available...
Mini Cat Cel Fix
Angled Cel Fix
Straight Cel Fix
Home
Emissions
Express mail-USA
Express mail- Int'l.
Privacy Statement
Dealer Inquiries
F. A. Q.
Contact Us
Home
Mini Cat cel Fix
Angled Cel Fix
Straight Cel Fix
Emissions
Express mail-USA
Privacy Statement
Dealer Inquiries
F. A. Q.
Contact Us
Home
Mini Cat cel Fix
Angled Cel Fix
Straight Cel Fix
Emissions
Express mail-USA
Privacy Statement
Dealer Inquiries
F. A. Q.
Contact Us
Home
Mini Cat cel Fix
Angled Cel Fix
Straight Cel Fix
Emissions
Express mail-USA
Privacy Statement
Dealer Inquiries
F. A. Q.
Contact Us
Old Dec 29, 2016 | 08:41 AM
alpha3's Avatar
i monitored the voltage of both downstream o2's and bank 1 is all wonky for sure. i ordered a new o2 to see if that fixes the issue. i just dont see how one cat could get messed up and the other is fine. but who knows. ill let you know the out come. if i feel like it after work ill swap the o2's and see if the problem follows the bank 1 sensor. should have done that before ordering the sensor but it was only 15 bucks.
Old Dec 31, 2016 | 10:50 PM
alpha3's Avatar
Got the new o2 yesterday and installed it this am. Drove about 400 miles today and no code.
ShirtaDay.com
May 18, 2010 03:38 PM
Prym
Mar 18, 2010 01:26 PM
