Air Suspension Question/Clarification
Old Sep 29, 2016 | 03:33 PM
Koobs2000's Avatar
Default Air Suspension Question/Clarification
Hello everyone reading this!!
I was hoping for some help and clarification:
I have a 03 H2, with rear end sagging. I have been reading posts about this issue so i have some fair knowledge but some things I need some help with.
When i turn on the ignition (before starting) I can hear a solenoid or relay kick on with the compressor for 4 small 2 second bursts. I can feel this occur when i place my hand on the compressor. After that nothing, and the dash display gives me a air suspension error of sorts. I can also turn the key further and start the vehicle. At that point everything repeats itself. Is this a normal process?? Is the compressor priming itself? Nothing happens with the bags at this point either.
Also, is there a way to manually fill the airbags with a garage compressor without splicing any hoses or air lines? I need to fill them up and see if they are leaking?
Can the ride height sensor cause my issue?
I dont have any scan codes since from reading other posts my OBDII scanner will not do the job.
Also, how does the shrader valve work in the trunk. It seems I can fill the compressor manually but not my tires. Is there an adapter that I need to buy? Is this connected to the same compressor that fills the bags?
I hope I was specific enough!!
Thank you!!
Old Oct 7, 2016 | 02:21 PM
H2CANEPADESIGN's Avatar
The schrader valve in the back is for an airhose to connect to that fills your tires, You have whats called a "dual stage compressor". It came with the adventure package. As far as the Air Bags not inflating you may have burnt the compressor out. I would disconnect a line, make sure the rear end is not lifted and start it. If there is no air coming through the air line that connects to your compressor then you may have other problems. there is a thread on these forums regarding converting to a coilspring.
Old Oct 10, 2016 | 03:50 PM
Abe's Avatar
Abe
Default Great tires at affordible prices
Have them on my hummer h2 sno2, mud street just great traction not disappointed 3d
http://www.treadwright.com?afmc=41
PewterTank
Dec 9, 2019 01:41 PM
calif phil
Feb 25, 2011 01:00 PM
KuyaRomeo
Jan 10, 2011 07:09 AM
tugboat patti
Sep 15, 2008 07:18 PM
SafariHummerH2
Jan 28, 2008 09:27 PM
