air suspension
Old May 17, 2008 | 04:50 AM
mb7050's Avatar
Default air suspension
anybody know where I could find wiring diagram for 2003 hummer h2 rear air suspension ?
Thanks a million
Old May 17, 2008 | 06:46 AM
vkh2's Avatar
Default RE: air suspension
ORIGINAL: mb7050
Thanks a million
Hi and welcome this is from 03 H2....hope it helps you out
[IMG]local://upfiles/140/FB3BD16DB52B44D58B18CD8D62B4DC05.gif[/IMG]
[IMG]local://upfiles/140/76AAB68AEE7B4565851B2499163F9F82.gif[/IMG]
[IMG]local://upfiles/140/0D55D6CD95D2476680D1A882323D8C12.gif[/IMG]
Old May 17, 2008 | 07:58 AM
mb7050's Avatar
Thanks that helps a lot.
Old May 17, 2008 | 08:15 AM
mb7050's Avatar
Do you know what are the correct voltage reading thatrear air suspension height positionsensors should give out min and max? after system is calibrated ?
I´m planning to install aftermarket height control module that can control those height sensorsvolt readings independently so I can adjust both rear airbags heights independently from cabin. But also keep the factory height sensors in place and working...
Old May 17, 2008 | 11:13 AM
vkh2's Avatar
ORIGINAL: mb7050
hmmmm,guess the only way to find out is to connect a TechII that will give you the voltage readings,or maybe some other member here can help you out on that
are you in Finnland ? I'm bringing my H2 over to Lithuania in early July but guess distance would still be to big for a meet
Old May 17, 2008 | 11:55 AM
hummech could answer the question for you.
Old May 17, 2008 | 12:35 PM
mb7050's Avatar
yep I live in Finland .
PewterTank
Dec 9, 2019 01:41 PM
calif phil
Feb 25, 2011 01:00 PM
mparrish
Dec 13, 2006 07:08 PM
ogdel314
Apr 25, 2006 10:44 AM
