Air Horns?
Old Jan 18, 2008 | 08:49 AM
dooks88's Avatar
Default Air Horns?
I did a search to see if you guys are using air horns. Didn't find much... Saw some good looking kits on ebay for around $150. Anybody have actual experience with putting air horns on the 3? Thanks.
Old Jan 18, 2008 | 09:01 AM
IHNEVELS's Avatar
Default RE: Air Horns?
I installed a set of horns on my H3. easy to do. go to walo.com and look at what they have. mine cost around $100.00 it has a self contained compressor. and these are pretty loud horns. mine are mounted behind the grill on the center post. i have the 418 powerhouse horns. you will like these.
Old Jan 18, 2008 | 09:29 AM
Hummer Guy's Avatar
I had a set of Grover air horns once, and a big ole tank mounted to the frame -- it was kind of a pain, but just as loud as a Semi - it was worth it! I also had the horns in behind the grille and just ran tubing from the rear part of the frame.
Old Jan 18, 2008 | 09:35 AM
crank's Avatar
This is what I'm doing now... Whelen Airhorn and speaker. about $250.
http://www.lshlights.com/AMAZING/itemdesc.asp?CartId={D31BA915-2733-4744-9F88-E021EF9A58EVEREST05}&ic=PAH112&eq=&Tp=
http://www.lshlights.com/AMAZING/itemdesc.asp?CartId={D31BA915-2733-4744-9F88-E021EF9A58EVEREST05}&ic=SA315P&eq=&Tp=
100 watts of pure ear piercing noise!
or this works pretty good too.
https://www.hummerforums.com/m_114355/tm.htm
This was about $50 and really works good. 60 watts can wake the dead. It even has sirens that can get you into trouble if not careful.
Old Jan 18, 2008 | 09:46 AM
crank's Avatar
It doesn't look like the above url works.
The unit is the Whelen PAH112 and speaker Whelen SA315P 100 watt. The bracket is the universal. The prices are up and down depending on where you buy it. You can buy the Whelen PAP112 that has the PA with the Airhorn. Just in case you like saying hi to the babes!
Old Jan 18, 2008 | 02:58 PM
mkielbas's Avatar
I got Wolo Bad Boy. it took me maybe 20 minutes to install... It's loud as hell
Old Jan 18, 2008 | 03:08 PM
RealJeep's Avatar
Why would you want a siren on your truck??? You'll get arrested for that in FLA, even if you're a vollie, you can't have a siren.
Old Jan 18, 2008 | 03:52 PM
crank's Avatar
The Whelen unit is a airhorn ONLY.
Old Jan 18, 2008 | 06:16 PM
dooks88's Avatar
I dont need a siren or loudspeaker, as fun as it would be. I dont need any help getting pulled over. My tint is very dark, and it gets me in trouble sometimes.
Old Jan 18, 2008 | 07:07 PM
SteveO's Avatar
Let us know what you get....I want to change out my wimpy horn too.
