Air-Compressor
Old Apr 3, 2008 | 10:33 PM
HARDxCOR3's Avatar
Default Air-Compressor
Stopped into Harbor Freight today in Saddle Brook, NJ and picked up a 12vdc air-compressor on sale for 49.99 here's the link
http://www.harborfreight.com/cpi/cta...emnumber=93186
Old Apr 4, 2008 | 08:31 AM
Trey124's Avatar
Default RE: Air-Compressor
Not too bad, 3 mins. to air up a tire.I went with the PowerTank which is more expensive, but you can run some air tools in case you breakdown on the trail.
Old Apr 4, 2008 | 08:39 AM
dwaxman1's Avatar
Did you mount this inside, in the back?
Old Apr 4, 2008 | 09:11 AM
shortbus's Avatar
it will fill a CAR tire in 3 minutes - plan on a bit more time to reinflate the tires on the H2. looks like a good deal though. all it needs is a quick connect power plug so you don't have to open the hood to connect it to the battery.
Old Apr 4, 2008 | 09:27 AM
dwaxman1's Avatar
you can't mount it for good inside the back? Wasn't there an option to have one inside from factory?
Old Apr 4, 2008 | 11:12 AM
shortbus's Avatar
the factory mounted compressor mounts under the chassis, behind the rear differential. there is no inside compressor mounting location, at least not on the early models.
Old Apr 4, 2008 | 09:31 PM
dwaxman1's Avatar
hoq is the factory one, any good??
Old Jun 18, 2016 | 06:11 AM
tonym4's Avatar
Looking to replace my OEM compressor for a better one to use power tools. Any tips?
Old Jul 6, 2016 | 03:40 PM
honda400ex2003's Avatar
any number of compressors would probably work, size is the main concern for getting it in the back. you might even be able to find a direct replacement compressor that is aftermarket if you have an OEM number to reference to.
steve
valleygirl3000
May 1, 2008 05:58 PM
HammerDown
Dec 30, 2007 05:32 PM
GameY2J
Nov 10, 2007 08:57 PM
azz7772
Oct 13, 2007 05:12 AM
mparrish
Dec 13, 2006 07:08 PM
