after market radio
Yes. With the correct adapter pretty much any aftermarket stereo will work. Had a Sony that retained everything in my 04 and now I have a JVC that retains everything in my 08. Check out crutchfield.com even if you don't buy from them they are a great research tool.
Does your OEM DVD in the rear still work too?
Yes it does. Crutchfield had all the adapters necessary. Only thing I didn't retain was the factory nav. To keep nav you have to buy a head unit that has it. And pretty much any aftermarket nav will be better than the stock one. It was pretty rough.
Wow, this sounds promising. I'm mechanically inclined not tech savvy when it comes to sound systems. Does Crutchfield walk you through the options, or do you have to know what to look for as far as adapters?
Axxess AX-ADGM01 Interface Harness Connect a new car stereo to select 2006-up General Motors vehicles (retains Bluetooth, warning chimes, Retained Accessory Power, and OnStar) at Crutchfield.com
Axxess AX-ADBOX1 Interface Module Connect a new car stereo and retain many factory functions in select 2000-up vehicles at Crutchfield.com
Axxess ASWC-1 Steering Wheel Control Adapter Connects your car's steering wheel audio controls to select aftermarket car stereos at Crutchfield.com
Metra GMRSAV Factory Integration Adapter Retain the factory rear seat entertainment (RSE) system in select 2007-up GM-built vehicles at Crutchfield.com
Metra 40-CR10 Antenna Adapter Works with select 2001-up vehicles ? Motorola plug to snap-lock female antenna jack at Crutchfield.com
Metra 95-3305 Dash Kit Fits select 2006-up General Motors vehicles ? double-DIN radios at Crutchfield.com
These are the adapters that came with my order. they are pricy on their own but the antenna adapter and dash kit are free if you order a stereo and the more expensive adapters are considerably discounted.
