Adjusting Parking Brake
Old Dec 31, 2007 | 11:55 PM
khoolhandz's Avatar
Default Adjusting Parking Brake
Can anyone tell me where the access is for the Parking Brake adjustment? I need adjustment on my H3 manual tranny.
Old Dec 27, 2010 | 10:45 AM
Jogi's Avatar
Default Adust Parking brake H3
Anybody has an answer please. Tx
Old Dec 27, 2010 | 02:46 PM
DJINCO's Avatar
On the frame, under the drivers side, about the middle of the door.
Old Dec 27, 2010 | 04:48 PM
Broken Halo's Avatar
Even though we have 4 wheel disc brakes, the parking brake is actually a small version of a brake drum, with small brake shoes, on the rear wheels. That is your parking brake. The adjustment on the cable mounted to the frame, is to take the slack out of the cable. If you've ever adjusted the brake shoes on an older vehicle (by using a 'spoon' type brake tool, and rotating the star wheel adjuster), that's how you compensate for wear, and adjust the parking brake.
Old Dec 27, 2010 | 06:36 PM
drtom's Avatar
Banned
kinda makes ya wunder how it would EVER wear and or get out of adjustment,,huh?
even if i ever used it ,which i dont, i gotta wonder just how it would wear,,,
Old Dec 27, 2010 | 07:27 PM
I know what you're talking about drtom! It seems to me the only way to wear them out would be to forget that you've got the brake set, and start driving.
Old Dec 27, 2010 | 10:01 PM
drtom's Avatar
Banned
yikes!!,,,i can smell it !!
Old Dec 28, 2010 | 08:10 AM
08xcab's Avatar
The cable stretches from use. I also have a manual trans and use my parking brake often when warming up my H3. Be careful adjusting it though...I broke mine. The threaded end on the cable was a little rusty and after a few turns with a wrench...SNAP! You can NOT buy just the cable. You have to buy the pedal assy. and it come with the new cable attached. Its not to pricey..it was about $60 retail. It was however, a MAJOR pain to install. You have to un-bolt the clutch pedal assy and remove it from the mounting studs to get the parking brake assy out. I didnt have to remove the drivers front inner fender to get the cable through the floor. There was enough room to get your hand up in there and guide the cable down. I also gave the new threaded cable end a good coat of anti-sieze so that later adjustments will go a little easier. Good luck!
Old Feb 19, 2018 | 05:31 PM
sturgisguy's Avatar
Talking
Penetrating Oil people..... Penetrating Oil... I hadn't touched my adjustment cable on my 2006 H3 until today (2/19/18). I sprayed it with penetrating oil and then let it set for an hour.... The adjustment nut turned easily.
ingydrummer
Nov 27, 2020 11:56 AM
lucky19942001
Oct 24, 2019 12:41 PM
wfturner
19
Jun 23, 2011 07:49 AM
susies59
Jul 10, 2010 02:42 PM
chsnprodigy
Jun 25, 2007 11:10 AM
