Adjusted my torsion bars
Old Mar 16, 2008 | 12:00 PM
solarflare's Avatar
Default Adjusted my torsion bars
That was one of the easiest adjustments that I had to do.....had to go get a 1 1/16" socket to fit the torsion bar bolt, but other than that, it was easy. I had been noticing that my H3 sat a little crooked....I kept saying NAH!
Finally got out the measuring tape, and it was almost 1" higher on the passenger's side. I lowered the passenger's side down, and then raised the driver's side just a tad. Now it's perfect! The front should get the same measurements on both sides and the driver's side rear will be about 1/4" down from the passenger's side, due to the gas tank, and how much gas you have in there.......
Alignment seems to be fine, but if something funny happens to my tires, I marked the bolts, so that it can be returned to the original specs.
Old Mar 16, 2008 | 12:13 PM
rhill20's Avatar
Default RE: Adjusted my torsion bars
Make sure that you check the measurements again; after you drive around a little it may be off again
Old Mar 16, 2008 | 12:18 PM
solarflare's Avatar
Rich, yeah I did......It seems good now, but I will keep checking for the next week or so. The only other thing I noticed was that the passenger's side bolt was really easy to move, while the driver's side you needed to put a little muscle into it...Is this normal?
Old Mar 16, 2008 | 01:03 PM
Muddydawg75's Avatar
did you jack the front end up of did you armstrong it?
Old Mar 16, 2008 | 04:26 PM
solarflare's Avatar
I didn't jack it up.....didn't want to move my dodge to get to my jack.....so I used my muscles!![sm=bounceybounce.gif]
Old Mar 16, 2008 | 04:30 PM
rhill20's Avatar
that's the same way I did it Solar, thinking maybe it was harder on one side than the other because you cranked up one side first (probably the easy side) then all the weight was leaning on the other. Does that make sense?
Old Mar 16, 2008 | 06:25 PM
stonewallmp5's Avatar
Just a guess but I think the passenger side was easier because you were lowering it, so the weight of the vehicle made it easy. nice ride!
Old Mar 16, 2008 | 06:54 PM
rhill20's Avatar
ORIGINAL: stonewallmp5
Good point, I was thinking "raise it" because that's what most of us do with them. Sorry
Old Mar 16, 2008 | 08:32 PM
josh1899's Avatar
Mine varies about 1/4 - 1/2 and inch from side to side depending on how much gas is in the tank. Full tank= spot on even. Empty= 1/4 inch higher on drivers side.[8D]
Old Mar 18, 2008 | 06:29 PM
gmpartsdude's Avatar
If you adjusted it an inch then your alignment that you just paid for is off. I adjusted mine about an inch and now my steering wheel is all messed up. I have to take it in for an alignment.
