-   -   AC OFF?? (https://www.hummerforums.com/forum/private-sale-trade-classifieds-10/ac-off-11447/)
Destroyer 04-14-2008 10:27 AM
AC OFF??
So i was messing around trying to change the horn that beeps with the lock button. i couldn't remember how to do so i was way off evidently because now when i turn the ignition on it comes up on the display AC OFF. i did not get a manual with my ride so i ahve no clue what i did. any ideas??
Hummer Guy 04-14-2008 11:54 AM
RE: AC OFF??
AC (Air Conditioning) OFF
This message displays when the engine coolant temperature is too high and the air conditioning in your vehicle needs to be turned off. See Engine Overheating and Climate Control for more information. This message displays along with the ENG HOT message.
3hummers 04-14-2008 11:57 AM
RE: AC OFF??
That sounds worse than I turned my AC off.
alrock 04-14-2008 12:19 PM
RE: AC OFF??
you can also download a manual at the GM owner's center.
https://www.mygmlink.com/main/US/en/gm/mygmlink
3hummers 04-14-2008 12:38 PM
RE: AC OFF??
I had that written down somewhere and lost it. Thanks.
White08H3 04-14-2008 03:58 PM
RE: AC OFF??
ORIGINAL: Destroyer
May be a stupid question on my part...but the horn can go off when you hit the lock button on the remote? Mine right now the lights just flash and when I am far away I can't tell if the lights go off in the sun...the horn going off would help.
alrock 04-14-2008 04:07 PM
RE: AC OFF??
Yes, check your owner's manual, it's in there. It's also here in the forums, somewhere, I'd have to SEARCH, but I think it could be found.:D:D:D (No offense, White, just feeling sarcastic)
Hummer Guy 04-14-2008 05:24 PM
RE: AC OFF??
ORIGINAL: White08H3
To set your choice for this feature:
[ol]With the engine off, turn the key to LOCK/OFF. Do not remove the key from the ignition.
Press and hold the lock and unlock buttons on the RKE transmitter at the same time. Hold both buttons until the DIC display shows the current RKE feedback mode.
To view the next available mode, press and hold the reset stem until the mode appears. Release the reset stem and press and hold again to view the next mode.
Once the desired mode is shown on the DIC display, briefly press the reset stem to set your choice. The DIC display then clears. [/ol]
The following are the available modes:
RFA 1 (default):This mode flashes the parking lamps when you press the lock or unlock buttons on the RKE transmitter.
RFA 2:This mode flashes the parking lamps and sounds the horn when you press the lock button on the RKE transmitter. This mode also flashes the parking lamps when you press the unlock button on the RKE transmitter.
RFA 3:This mode flashes the parking lamps and sounds the horn when you press the lock or unlock buttons on the RKE transmitter.
RFA 4:This mode disables RKE feedback. There will be no feedback when you press the lock or unlock buttons on the RKE transmitter.
