AC
Old Mar 6, 2011 | 04:12 PM
linemn1's Avatar
Default AC
I'm new here. I've got a 2006 H2, I've had it since 06. My problem is when I put in a HID conversion, my ac doesn't work right anymore. Diver-side works fine pass stays HOT. I've tried disconnecting the battery didn't work, I've tried removing the ac fuse and turning the key on, didn't work.. Any help would be greatly appreciated.
Old Mar 7, 2011 | 03:18 PM
luda81's Avatar
Where did you ground it at? Also did you try disconnecting the HID to see if the AC was going to work right again?
Old Mar 8, 2011 | 08:32 AM
mgurgone's Avatar
I have had a problem in the past with the climate control.... 1 side blowing hot and the other blowing cold. I was told it was a problem with the actuator (not sure if that is the right word or spelling).
Every time it has happened it always corrected its self once the truck was turned off. The dealer told me this was common with GM vehicles with this type of climate control.
It may be a coincidence with the HID install...
Old Apr 16, 2011 | 07:15 PM
linemn1's Avatar
Ok I tried taking the hid's off and disconnecting the battery, still didn't work. How can I tell which actuator is bad?
Old Sep 7, 2011 | 11:44 PM
linemn1's Avatar
Has anyone tried to change out the actuators, and if so how hard is to do.
Old Sep 7, 2011 | 11:52 PM
Its Hummer Time's Avatar
Its probably your actuator, not related with the HID. To change them I believe you have to remove your dash. Hopefully you do not have to remove your entire HVAC unit. That will be a pain.
Old Sep 8, 2011 | 01:49 PM
luda81's Avatar
I don't think it should be that hard except maybe taking the dash apart. and i believe the actuator that has gone bad controls the blend door for the passenger side so thats why its staying hot. Doesn't seem that hard to repair. But don't take my word on it.
Old Sep 9, 2011 | 12:41 AM
linemn1's Avatar
Has anyone ever done it them selves? Also do anyone know of a place where I can get a repair manual?
Old Sep 9, 2011 | 08:41 PM
XxCC3xX's Avatar
Cool
Try Automotive Repair, Auto Recalls, Automotive Software & TSB's - ALLDATA
Old Sep 11, 2011 | 09:34 AM
luda81's Avatar
I have that at my school. I use it all the time. It works very well except for wire diagrams.
