ABS and TC light came on??
Old Feb 1, 2016 | 07:59 AM
greaser2's Avatar
Default ABS and TC light came on??
Ok, so driving to work today and the ABS and TC dash lights came on at same time. I have a 2007 H2. More info, just dropped the gas tank and replaced fuel pump to correct a check engine light(Evap system leak). This is fixed. Thinking I may have loosened a wiring connector somewhere on the back axle.
What you guys think? Where should I look when I get home today?
Old Feb 2, 2016 | 04:57 PM
calif phil's Avatar
You need a scan to tell you what wheel sensor is responsible for the code. That will help narrow it down.
Old Feb 15, 2016 | 03:28 PM
greaser2's Avatar
Update, Scan said right front sensor. So, purchased a new one and installed (old one had been worn near in two by wheel as the cable was not in its retainer). Started it up and no more lights. Success right? Nope, as soon as I drive forward lights come back on. More testing I guess.
Old Feb 18, 2016 | 08:00 AM
calif phil's Avatar
Visually inspect the wiring that comes off the plug. Very common for the wire to break due to the constant up and down movement of the control arm. You can buy replacement pigtails at the auto parts stores.
thehammerh3
Mar 18, 2017 09:48 PM
Alex2012
Nov 16, 2013 06:34 PM
AKDropm
Aug 2, 2012 11:07 PM
sawyer1206
Mar 24, 2011 10:52 AM
07superbee
Dec 20, 2007 08:47 PM
