ABS light: New wheel bearing
Old Dec 16, 2016 | 08:14 PM
Synthetickiller's Avatar
Default ABS light: New wheel bearing
My google fu has failed me. I've seen a few threads on this topic, but can't find them now.
I installed a timken wheel bearing assembly & the abs/tc lights come on.
Is there a fix for this or is this something annoying that I have to bring to the dealer to fix?
Old Dec 17, 2016 | 07:09 AM
tharber's Avatar
Did you install a new sensor?
Tim
Old Dec 17, 2016 | 09:28 AM
NoSpoon's Avatar
Synth,
The new hub should have a wire coming off of it. Make sure that it's plugged in good. Maybe disconnect the battery for 10 minutes then reconnect to see if that helps.
Old Dec 17, 2016 | 09:44 AM
Tim
It does.
Originally Posted by NoSpoon
Synth,
The connector felt like it clicked in properly.
I will try to disconnect the battery & report back.
Old Dec 17, 2016 | 11:56 AM
I disconnected the battery for 10 min, reconnected the negative & it still shows the same error.
I know that I can connect the old hub to see if the symptom goes away. Will that point to a bad hub sensor?
Any other ways to reset stabilitrak?
Edit:
I did a little reading & an unrelated abs problem & solution came up.
Only the driver's side wheel bearing/hub assembly was replaced. I will do the other when I have time. The solution stated that both have to be replaced to get rid of a false ABS failure. Does this make sense?
Old Dec 18, 2016 | 04:08 PM
flyday58's Avatar
Reading on the Chevy forums most commonly it seems to be a missed connection when going back together, or replacing things in pairs, as you're leaning toward. People seem to have good results replacing wheel speed sensors in pairs.
Old Dec 19, 2016 | 10:07 AM
Thanks for doing the research.
I'll have to wait to do the other hub once the weather is bearable. I bet that's the problem. I feel much better about the situation.
At least I can say that both the lower ball joint, wheel hub and Cv joint was worn out beyond belief. I can tell tattoos it's riding better.
Old Dec 19, 2016 | 04:05 PM
H2Miami's Avatar
I replaced both hub for Timken and never got a light on .. Did you replaced both side , are the hubs from a reputable place
Old Dec 20, 2016 | 08:08 AM
H2Miami's Avatar
Checking my long term memory . I replaced one side first and the other took 3 months later and never got any code or light on. However mine is a 06 . May be different in yours .
Old Dec 20, 2016 | 10:50 AM
I ordered them from D-max store. They have a lifetime warranty.
As flyday58, I'm just hoping that it's because I didn't replace them in pairs.
I know the 08s/09s are a different platform, ecm, etc so there could be a different way in how the vehicle detects ABS.
