98 H1 suddenly starts leaking TRANS fluid!?!?!
Old May 1, 2010 | 01:18 PM
ctdrl-1's Avatar
Default 98 H1 suddenly starts leaking TRANS fluid!?!?!
My 1998 has never had a problem with leaking tranmission fluid in the past then all of the sudden I notice a large puddle under it so I go on the hunt to find what is leaking and its the Trans.
So I fill it back up with seal refresher and stop leak and it leaks out again so I fill it up again and take it for a nice long drive put it back in the drive way NO LEAK! I am happy.
I leave it over night come out in the morning, not a drop on the drive way, I am still happy I got to work come home 12 hours later and it has all leaked out again>>>>>
Any one have any ideas? the strangest part is how it held overnight then leaked all day even thought the truck never moved!.
Help
Brent
Old May 6, 2010 | 01:01 AM
hummech's Avatar
it is your dip stick tube seal. if the vehicle is on a slight down grade it will pour out from around the dip stick tube.if it is sittind on a flat on flat ground will most likely won't leak.
Old May 10, 2010 | 11:42 AM
ctdrl-1's Avatar
Thanks! Hummech, you could not be more right! It spent all winter in my garage ( level floor) and not a drop, but the leak started when I put it on the driveway, and it was backed in so the front is tipped down.
And I had already isolated the leak to the seal< man thats great, thanks for confirming what I fuigured was true befor I spent a bunch of money I didnt need to!
Brent
greg260
Jan 27, 2018 12:41 AM
triblk6spd
32
Mar 5, 2012 03:26 PM
HummerGuy
Jun 6, 2008 04:18 PM
dscaberboy
Nov 23, 2007 04:45 PM
whododat
Dec 2, 2006 12:30 AM
