98 H-1 need some Help
Old Oct 18, 2009 | 06:17 PM
GBergie's Avatar
Default 98 H-1 need some Help
I need some help
My 98 H1 will not Disengage from TC Lock
I was using my ride to pull a Motor home that was stuck in a driveway.
I was pulling forward in Low/lock and was just spinning my wheels on the street just for a few seconds. When I tried to go back to High Range (the way I've always done it -- pull forward 10-15 ft. then back up 10-15 ft. put trans into Neutral then shift into High) The TC Lock light doesn't go out and the Transfer Case is staying in High/lock
Does anyone have some ideas on what the problem is ???????
I really don't want to go the Dealer
GBergie
gbergie007@aol.com
Old Oct 18, 2009 | 10:07 PM
Pilot223's Avatar
I'm not an expert by no means but my h1 has the same issue sometimes try just going forward not reversing and continue to shift the trans into neutral i find the levers stick on the older trucks try and shift it into Low gear to just keep cyclling it it should come out of it
Old Oct 19, 2009 | 07:55 AM
Not uncommon for me to have to try several times. take it through the process several times and try to be on level ground when you do it. Tranny in neutral and strong, positive shift of the T-case to H. Drive forward 15-20 feet. It should disengage. Sometimes my TC light stays on for a minute or two.
Old Oct 19, 2009 | 04:46 PM
GBergie's Avatar
3hummer and Pilot
thank for the info I give it another try
G Bergie
branstone
Mar 20, 2007 02:54 PM
shmoney1
Feb 26, 2007 04:59 PM
importkiller
20
Jan 31, 2007 12:25 AM
HummerGuy
Oct 19, 2006 02:58 PM
shortbus
26
Jul 15, 2006 12:26 AM
