4WD QUESTIONS
Old Aug 2, 2006 | 02:40 AM
03hummer's Avatar
Default 4WD QUESTIONS
Hi everyone,
I'm new here i just bought an H2 2003 and i was wondering you know where you press on the dashboard to switch from
2wd, 4lo, 4hi, etc....(lights went off ).....b/c i was driving the h2 today for about 5miles and it was in i think 4UP " arrow poiting up "
and i tried to switch it after i stopped and had it in netrual and now all the lights dissapeared and now on the message instrument i see SERVICE 4WD " what does that mean exactly did i mess up the transmission or its an easy fix, please anyone w/ info help
new owner here
Old Aug 2, 2006 | 04:07 AM
Greenblade's Avatar
Default RE: 4WD QUESTIONS
ORIGINAL: 03hummer
Hi everyone,
new owner here
to switch from normal 4-hi-open to 4-lo you put the tranny in neutral and then hit the button. wait a second, you'll hear a light clank, and you're set. from there you can lock the rear differential (though locked isn't always best for traction).
in any t-case setting (lo, high open, high locked) you can engage TC2 which is helpful in mud. that's the top button under the t-case settings (under the lo/high buttons)
i don't know anything about SERVICE 4WD, probably i'd take it to a dealer if such a warning appeared
Old Aug 2, 2006 | 11:47 AM
Sugardaddy's Avatar
That's funny that this topic came up. Although I am having no problems with mine, I was reading through the manual last night and was somewhat confused about when and where to use the different settings. My prior vehicle was an 03 BMW X5, so I never had to do anything with the AWD. Thanks for the help.
Old Aug 2, 2006 | 01:23 PM
Greenblade's Avatar
ORIGINAL: Sugardaddy
yeah, the h2 is a vehicle that rewards you for sort of feeling out all the modes and things and seeing what works best for you in a given situation. Probably what works best for one person won't necessarily for another and so on. I think thats alot of fun - messing around trying to find the best mode. the rear locker isn't always good.
usually the error part of trial and error means you're buried, though.
Old Aug 2, 2006 | 03:47 PM
Sugardaddy's Avatar
ORIGINAL: Greenblade
LOL!! Thanks, now I just have to find a place around Pittsburgh that I can try it.
Old Jan 18, 2007 | 09:07 PM
thaidoggs's Avatar
I had the same problem. The service 4x4 light came on when shifting from 4 low to 4 high and stayed on till i had turned off the ignition and restarted the vechicle. The top button is 4 high with a 60/40 split the next down is also 4 high with a 50/50 split. Next is the 4 low 50/50 split and you must be in neutral and stopped to get to this drive. After you are in low you can use the tow option and the dif lock.
ReadyGun
Dec 9, 2013 03:23 PM
Hummer79
Jan 1, 2013 04:59 PM
intogaming
Oct 28, 2011 12:30 PM
Sundrop Addict
16
Mar 2, 2010 08:41 AM
julygold
Jul 24, 2008 12:37 PM
