4 High Lock Won't Disengage!!
Old Jun 11, 2007 | 09:50 AM
HumveeH3's Avatar
Default 4 High Lock Won't Disengage!!
How's it going? Long time reading, first time poster. This is the problem I'm having. My H3 for some reason today decided to go into 4 High Lock on it's own while I was trying to park. (I suppose the lack of off roading finally fed her up!) I pressed the "All Time 4x4" button and it lit up but I decided to drive out of the parking spot and see if the H3 was ok. This is when I noticed that even though the "All Time 4x4" button was on, the H3 was actually still in 4 High Lock. Called the dealer and the tech advised to drive it in reverse for 20 ft and then see if she's ok. Did this and it worked, but I wasn't sure that fixed the problem so I put her back into "4 High Lock" and drove a bit then back to "All Time 4x4" and again still in 4 High Lock. She's scheduled to be looked at but Iwas wanting to know if any more experienced "Hummer" owners have experienced this and what the problem was.
Appreciateany responses.
Old Jun 11, 2007 | 10:03 AM
D VADER's Avatar
Default RE: 4 High Lock Won't Disengage!!
Mine jumped to the second position over the weekend. I don't think so but I may have accidently bumped it. Anyway I switched it back with no problems. I didn't see the light on but noticed my tires were scrubbing, a sign of a locked differential.
Old Jun 11, 2007 | 10:42 AM
ZYNE's Avatar
Didn't someone else here have a similar issue and it turned out to be thetc motor needing to be replaced?
Old Jun 11, 2007 | 01:13 PM
mliebs8's Avatar
I'm curious as to what tires scrubbing means.
Old Jun 11, 2007 | 01:44 PM
Dennis's Avatar
That's when both tires are turning at the same rate and the inside tire trys and does continue to turn at the same rate as the outside tire does in a turn...That's why limitied slip differentials will let the inside tire stop turning in a turn and the out side tire continues to pull...The result is exsessive wearout on the tires and strain on the differential...also for this reason, you should not engage the lockers unless you expect to be driving in a a straight line with little or no turning on hard pavement.
Old Jun 11, 2007 | 02:21 PM
HumveeH3's Avatar
D VADER, I thought I might of accidentally hit the button also but both my hands were on the steering wheel since I was making a turn into the parking row.
As for the TC motor needing to be replaced, thank goodness for warranty!!
I appreciate the replies.
Old Jun 11, 2007 | 05:17 PM
Hummer Guy's Avatar
"All Time 4x4" button?Am I way to paranoid about trolls? If its true: Take it to the dealer, its clearly a malfunction that you wont be able to fix on your own.
Old Jun 15, 2007 | 10:25 AM
HumveeH3's Avatar
Hummer Guy, I appreciate the reply. As for being paranoid about trolls, No I'm not. As you may have read in the my first post, I'm new to the forums and was asking for those who have owned anH3 longer than I have if they have experienced this issue. The "All Time 4x4 button", I was referring to the button that is active during regular driving. I appologize for not reading the manual for the actual name/label of the button but it looks like everyone else who replied knew what I was talking about. I alsomentioned that the H3 was scheduled for maintenance so clearly I knew I couldn't resolve this issue on my own. I appologize in advance if I read your reply as a "Negative" response to my lack of knowledge of the4x4 system but I've come to realize on any forum that there are some folks that like to degrade those who are just asking for what "you" may consider as "Common Sense" information.
As to the condition of the H3, the tech checked it out and all was good. Apparently, 4x4's need to be placed in reverseafter switching back to "Normal" drivingand driven 20ft. Is this true? I don't know, but maybe you, "Hummer Guy", can answer this for me.
Old Jun 15, 2007 | 11:02 AM
Dennis's Avatar
Hey Joe..I never heard of that before..I cycle mine through all the 4x4 functions while standing still in neutral and they always return to normal...Sound like it ain't working right for you still...
Old Jun 15, 2007 | 11:22 AM
littlehummerboy's Avatar
Same here. In neutral, I can cycle between them all fine. At low speeds, the 4-Hi and 4-Hi locked always works as well.
