39in tires
Old Feb 10, 2008 | 09:21 AM
chukwagen's Avatar
Default 39in tires
Would a Fabtech 6in lift be sufficient to run 39in sts tires?
I know it says 38's in all the literature, but you figure that a 39in tire is only 1/2 bigger all
the way around than a 38. For you guys/gals running the same lift, is there
any extra room to play around with?
Old Feb 10, 2008 | 12:38 PM
GorillaH2's Avatar
Default RE: 39in tires
Mine is not lifted but yes you could probably even fit a 40 inch tire under there because evenat stock height it can handle 37s without a problem
Old Oct 23, 2012 | 07:03 PM
2004H2's Avatar
i was going to install a Fabtek 6 inch sup, kit...its calls for 37-40 tires....it would be $3,800.00 installed by our local 4x4 shop plus tires....
i wanted to put it on a Stock H2, 37x12.5x17, i heard people say thats what they have, with some rubbing on turns and out at play while off-roading, and drags the tires while hauling a boat or trailer, for an h2 w/springs......i have both boat/trailer....
others have the 6 inch lift by fabtek, they say the hight has no rubbing and w/37-42 inch tires they get full use of the wheels in rocks and mud and rides nice on the highway.......no problem with towing with 10 inch drop hitch.....total highth differance is 9 inches higher,than stock...H2
i hope i made a good choice......Rick
Caraddict
57
Mar 28, 2018 12:42 PM
Pelvicthrust
Sep 28, 2012 10:52 PM
Pelvicthrust
Sep 26, 2012 11:06 PM
smokemaster60
Sep 7, 2010 04:56 PM
05roush0090
Oct 30, 2009 06:51 PM
